Pics of the shell? Mainly lhr quarter side?
The shell has no dints / bog / rust or anything at all wrong with it.
The bodywork was in great nick before I started pulling it down.
See pics...
  • 1 month later...
Hi there, rear pods still available? What colour are they? and will they fit a S2?
Cheers.
Hey mate, I've still got them but they're on the car and I'd have to get them off without them cracking. They're black and in good condition and I'm fairly sure they'd fit S2 as well. Someone else may be able to confirm for you.
Got the coil pack bracket? Msg on 0497075260 if u do
Fairly sure they went with the coils when I sold them. I'll check tomorrow.
Hey mate. Pic of the leather gear surround? Searchin everywhere for one in good nic lol. Cheers.
Will be able to send you one tomorrownight or saturday.
Sorry, they went with the coils.
Sorry again, I thought I still had it but it went a month ago with a bunch of parts and the brake boot.
PARTS LEFT
HKS pod filter with adaptor Needs new foam $30
Intake manifold No sensors $40
Engine mounts $40
Radiator overflow bottle $20
Power steering pump $75
Fuel pump No label but was fine for 285rwkw $60
Clutch master cylinder $40
Manual pedal set $60
Tail shafts $70
o2 sensor $40
Front 5 stud hubs $60
Spare space saver wheel $30
Front upper control arms $50
Rear control arms $75
Master brake cylinder $50
Handbrake front section $40
Body shell Still complianced and registerable $250
Rear reinforcement bar $90
Bonnet latch $30
Spoiler - Series 1 No stop light and scratched $30
Bonnet Black - resprayed $120
Boot x 2 $50
Front wheel liner Front RH $15
Series 1 tail light RHS $40
Indicators Nismo Side - clear pair $35
Front Recaro $150
Interior wiring loom $120
IP cross car beam $50
Rear seats $50
Instrument panel Standard black good condition $50
Headliner Excellent condition $30
Pillar trims $20
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
