Hey Guys,
Maybe a bit of a silly question but I want to install a oil catch can but not 100% sure on the how. Is it as simple as just putting inline? And I am thinking I want a oil catch can for the PCV hose drivers side and also on the intake passenger side. Do I need to use 2 catch cans or can I rig up one catch can for use on both side? And I want to keep it legal.
I want to do this as a bit of troubleshooting procedure more than anything. My car runs absolutely fine except I still see some smoke for a few seconds when reapplying throttle after a 10sec backoff decelleration @ 80kms or more. Or if the engine is warmed up and idling in park I rev it high, then the revs drop back down to idle and some smoke clears, but recently I tried this rev test on a hot 33*C days after 45mins of driving with aircon on and nothing! No smoke. So the issue seems intermittent. This issue only started after an accident where the wife snagged the exhaust and ripped it clean off which was only 1 month after a turbo upgrade/replacement as the original stock turbo blew up.
https://www.dropbox.com/s/1lvc2hgifqkuajy/Stag%20Smoke%20Blow%20Short.mp4
Paul.
https://www.sau.com.au/forums/topic/438831-vq25det-oil-catch-can-setup/
It almost sounds oil pressure related, when the oil is hot it's thinner and has less pressure. Can you try a thinner oil perhaps? What are you running now?
Were the banjo bolts drilled out? Perhaps too much for your turbo seals?
Dropping a catch can in will show you if there is blow by etc, but it won't fix the underlying issue. Have you checked the PCV operation?
Hey Scott. I thought one might have been missed but Craig said that all 3 were drilled out now.
Currently running 10w60 castrol edge performance. Was running motul chrono v300 10w40 for a year. The 10w60 has reduced the amount of visible smoke frequency. I say it only happens when driving @80km or more but really its when the engine reaches max vacuum then i apply gas again. I have a cheapy boost gauge with max vacuum reading down to -15psi. At idle its around -9 to -10psi (-7 to -8 in drive and stationary). But i noticed when I do that "zippy" driving in back streets using only 1st and 2nd gear the car reaches -15psi easy when its all phsyc'd up. This is when smoke become visual looking in rearview mirror.
Like you say I know the catch can wont fix the issue but at least maybe I can get a indication of how much blowby gas there might be. I just need to start doing things to troubleshoot.
PCV seemed to work fine but I replaced with brand new genuine nissan PCV about 6 months ago. Made no difference.
Where is the smoke coming from? If its coming out the tail pipe then its the opposite of blowby - oil getting past the rings and there's not much you can do about it short of new rings! You could check by doing a leak-down test to se if its your valve seals.
I still think it might be the turbo seals, I have a Soarer I work on with a similar issue, nothing I do can stop the turbo seals leaking, but it isn't all the time, and mainly on decel.
Any chance you can drop the front pipe and check the dump for oil buildup? Shame the turbo is so hard to get to...
Drop two catch cans in if you can, it will at least tell you if there is an issue with the PCV or breather and rule them out.
I now have the ability to jack the car up on stands and work from home now. I'll try to have a look at the dump pipe for oil build up. Is it enough to look at it when cold? Or should I go for a hard drive then check (so super hot)?
After this might look into leak-down test. And still interested in getting catch cans.
Catch cans aren't hard to fit, there are a few photo's of my setup in here somewhere.
You can't drop the front pipe when it's hot, just check it for wet oil when cold.
A compression/leak down test is a good idea. I just bought a tester myself for $40.
It all looks pretty clean, other than the intercooler piping. Could be coming from the rocker breather or the turbo seals.
Running a catch can will rule out the rocker breather, try it for a few days just venting under the car and see if the oil stops. Best if you clean the intercooler and piping so you can see if it is still filling with oil. If it is, it may point to a turbo drain problem, which isn't too hard to check anyway.
  • 1 month later...
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
