Hey all m35 Nismo ECU owners having an issue with the nismo ecu after install seems to idle really low and stall at the lights or sitting in traffic and has thrown a CEL.
Has anyone else had an issue with there nismo ecu idling low,stalling and throwing a code or any ideas on what the issue could be?
Cheers fellas
https://www.sau.com.au/forums/topic/439280-m35-nismo-ecu-low-idle-and-stalling/
Have you done an idle air reset? Every car is different, if you've just thrown in a used ECU I'd suggest that it doesn't know that your car isn't set up for what its used to. I'd give that a whirl, procedure detailed here http://www.skylinesaustralia.com/forums/topic/275099-m35-still-stalling-not-idling-properly/#entry4662009
Ok so I did idle learn reset and all other diagnostics I could but to no avail car is still stalling.
I took out throttle body, BOV, MAF and cleaned it all, still stalls when at a stand still or coasting under 1000k. Then I took the vacuumed line off the FPR and I didn't stall as quick but inevitably still stalls after about 30-40 seconds at a stand still. So I'm stumped as to what the issue could be. Maybe MAF maybe FPR?
I thought it weird that it idles better with the vac line off the FPR though.
Any more thought gents?
Yeah it was sweet before Scotty just put in the nismo ecu and it has started stalling. I'll change back to the OEM ecu tomorrow and see how it goes but not sure why the nismo would cause it.
It's from a highly regarded m35 owner on this forum. I'm sure he wouldn't be selling shit parts as it runs well just not that great when at a standstill. It's given more low to midrange torque speed limit cut and revs higher all is sweet except the idle.
Cheers for the helpful comment davelol
Lol sorry mate didn't mean to sound like a dick!
I know brick was selling it and he's a top bloke. Did he have issues running it in his car? Think he said it was a bit rich...
When we do tunes on cars at work, whether it be a re-flash or a piggyback module, if they do what your car is doing, we always send the tuning file back and keep trying till we get a good one, or we send the module back under warranty. The point I was trying to make was, if you changed absolutely nothing else on your car except the nismo ecu and it started stalling, it's very likely an ecu problem.
Get an emanage on it, at least that way you can adjust the fuel.
No point adjusting the idle screw on an electronically controlled car. You need a consult 3 to set the idle properly, but if the AFR's are out it won't help.
Hey scotty, does that mean a nissan dealer would be able to adjust the idle?
ECU may have run well on the sellers car but is yours exactly the same configuration... exhaust, intake, turbo etc?
Most probably. As long as the map is suited. If it's overfuelling then a throttle re-learn won't help much.
  • Like 1
All good dave I didn't take it as an attack. Lol
Brick was running a touch rich but was still running rich with the OEM ECU still in after. It runs ok with the vac line off the FPR which I thought was wired and not sure why that is but any ideas on that would be helpful.
Scotty I plan to go down the route of an emanage just saving up for it need to pay a few parking fines first lol.
I plan to take it to Nissan on Friday and see if they can adjust the idle through the consult. Otherwise I guess I just have to learn to have a aware right foot and manually keep the revs up where they need to be till an emanage can be sourced fitted and tuned!
But brick all idle issues aside cheers for the ecu and enjoying the better low to mid range torque and repsonse it gives!!! Thumbs up mate!!
  • Like 1
So it's running lean at idle then... Taking the vac line off at idle would richen it up I think. Perhaps it was just setup with an adjustable fuel reg initially...
I would be getting it on a dyno before anything else... Perhaps with an adjustable reg in place so you have some control over mixtures. Otherwise, go back to the stock ecu until you have the Emanage installed.
It's unusual, I would have thought the o2 sensor would have sorted it out, it must be a fair way out...
  • Like 1
So I couldn't get the car to Nissan today as worked dragged on. In the mean time I'll get my hand on a nismo FPR and gauge to adjust the pressure. What should the stock pressure be for the fuel? Is it around 30-40PSI? From memory.
I spoke to a few dyno places a while back and said they can't dyno tune my car as they don't have a suitable harness for it? Would that be the case as I thought there OBDII and most can connect to that.
Seems to have some hesitation when accelerating hard now aswel feels like air cut!? Weird!!
Cheers for the advice guys.
If no luck with Nissan and a dyno tune I'll just have to go back to OEM and wait for the emanage to get it all sorted.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
