Hey guys I own a 1991 R32 GTR I recently just put HSD Monotube coilovers on. I currently have 18x10 +18 Work XD9's and the guards are not currently rolled but will be soon. I max'd the coils front and rear and the front were about 323mm from the center to the top arch and the rear is 330mm from the center to the arch. Now I know of the consequences of running a GTR to low, Bump steer, CV boots and the drive shaft being on an acute angle and loosing HP. The answer I can't find is at what height this becomes a problem, I like the look of the car running 330mm front and rear for height just wondering if you guys think this is to low and the following problems will occur, Thanks!
https://www.sau.com.au/forums/topic/439378-r32-gtr-hsd-coilovers-what-height/
Skdneykid used to say that 350 front 340 rear is about as low as you could go before it all went to poo (and that requires a bunch of adjustable bushes or equivalent to align), but it sounds like you're going for a look not for performance, right?
Really wow I thought it was closer to 340 on both, and I'm after best of both worlds. I like the look of having a lower car but don't want to loose performance, I might try to get away with 340/340 and see how it drives
Fair enough, but I think that setup may make the GTR understeer more than it would at 350f 340r. Remember that front guards have a larger opening to deal with the turning wheel, so you would expect to have a larger number at the front.
The problem with the HSD's is that you can't really get close to 340 front or rear, the highest I have gotten mine (Although a GTS-T, not sure if GTR coils have the same issue) is around 330 eye brow height. Although I have a bunch of adjustables to compensate ;)
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
