The lesson I learnt today, is always make sure your bonnet is securely latched.
Whilst doing 100km/hr down Roe Hwy and yourbonnet pops up the results are not nice:( I now have a very bent bonnet, a smashed windscreen and a caved in roof.
It's also very difficult to see where your going when you have a bonnet covering your windscreen. I've learnt the hard way, and will be using bonnet pins to hold down my next bonnet. It will be at the smash repair place for many weeks:(
But you have to laugh about these things:D
Will try and post some pics up on Monday for you amusement:D
Cheers
Paul
https://www.sau.com.au/forums/topic/43944-learning-lessons-the-hard-way/
  • Replies 56
OMG. You gotta laugh hey, it's the only way you'll be able to cope with the repair bill!
Funnily enough, the exact same thing happened to a mate of mine, his bonnet flew up doing 100+ also, bent the hinges right back, smashed the crap outta the roof too, luckily he didn't need a new roof though!
Paulie, think it's a sign that a CF bonnet should be installed!
Holy Shit Paul can only imagine it would have scaried the f*#k out off you. But good to see that the only medicine is to have a laugh about it coz get shitty will get you no where. As for a CFB well i can tell you they flex around like you wouldn't believe, can scare the hell out of you when you are sitting behind another car. Come to think of it I should invest in some bonnet pins.
Hope the repairs go smooth for you. :(
I appreciate all the thought's guys, but with luck insurance should cover the damage, so it's just one of those things that happens.
Yes, it did scare the crap out of me, and with a bonnet covering the windscreen it doesn't give you much room to see where you are going;) I'd like to go cbf, but the cops don't think that is safe:rolleyes: .
If anyone does find a R33 roof anywhere then please let me know, as that will be the only major holdup to repairs.
Thanks
Paul
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
