Hi Guys,
For a while i have been thinking about starting a thread, updating what i do to my GTR. As most of the performance stuff has already been done it will be pretty much all cosmetics.
So first things first. A bit of History.
Bought the car from a local guy here in Canberra.
3 Months later my engine went Bang cause: Dirty fuel caused massive detonation. Cracking Piston #2, did a bloody good job of it (it was actually split in half). And the Piston rings had melted to the pistons. Obviously it had a very lard life.....Here is was the compression test:
1/15
2/0
3/25
4/125
5/90
6/50
9 Months later i had it back with my full forged bottom end and completely new fuel system. Here is what the engine looked like directly from the rebuild for the run in.
When the car was being rebuilt i had a look at the turbos (looked almost brand new) and took the gamble to leave the stock ceramic turbos in as i love my response. heinsight is a wonderful thing. 500KM into the run in phase i spat the exhaust wheel from 1 of my turbos into my cat. Sigh. Ultimate tunes where kind enough not to charge me for the labour to install new turbos. Thanks again guys.
Decided to go with -7's to try to keep my response levels to where i like them whilst having a bit more power.
Kept going through the run in phase. On the way to work i lost an AFM. Back in it went. Again ultimate tunes didn't charge me at all for the AFM! Can't recommend them enough. Anyway after that it has pretty much been smooth sailing.
From there about 3 months after the run in and everything was smooth i decided to add a bit more. This time it went in for the following:
New catch can
Tomei Type B cams and adjustable cam gears
Full Painting of the head (Bayside Blue)
Z32 AFM.
Also put stock BOVs in as my ones where ATMOS and i hated them.
Since i had asked to replace the cams Adrian decided to pull the head off to make sure that everything was A OK with the engine. Since that was off i decided to pain the Plenumm as well. Here is how it came back to me:
From there i decided to start to try out a few things. I managed to track down a set of Original stickers for my wheels (Took me 4 months of searching, 5 minutes for someone on SAU). Very happy i found these...
Next came a bit of fiddling with the engine bay. Painted both the radiator overflow and the washer bottle:
I also managed to track down a fuse box cover for $5 so i bought another one and pained that black as well.
Next i decided on a strut brace. I spent probably 2 months thinking about what strut brace. Was going to go a MINES strut brace but decided that i could not justify the extra $1000 over the HKS Kansai. So i went the Kansai, and at the same time i replaced my POD filter element with a blue one and bought a Nismo vision cover:
Now we are pretty much up to date. But i still have so much more to do. Plans for the not too distant future:
HKS hard pipe kit
Koyorad 53mm radiator
Full braiding lines for the fuel system, catch can etc..
Re do interior with new dash, Nismo interior and other little bits and pieces
and as i go restore parts as i see fit.
I have literally just ordered another $200 worth to go in ASAP. So stay tuned....
If you have any feedback/Ideas input is welcome!
https://www.sau.com.au/forums/topic/439497-anfanee-r32-gtr/
First update was what i did last night...
Pulled off my Number plate lights and reverse lights and gave them a clean:
Noticed that both of my reverse lights now have cracks in them... Anyone know where i can get new replcements?
Since i had the kit out i did my rear tail lights as well!
Exhaust a little bit of a polish, noted that one of the mounting brackets have come loose so ill pull it off in the next few weeks and re weld it.
And finally gave my number plate a bit of a scrub to top off the look. All these parts will be coming off next week again anyway so ill give them another clean then.
https://www.sau.com.au/forums/topic/439497-anfanee-r32-gtr/#findComment-7206791
Did the inner door cards. Credit goes to RBN1 for this idea. Loved it so much i had to do it. Subtle change that looks amazing!
Loving the look. I think that is all the CF i will put in the interior as i have other plans. More details to come in the next few weeks.
  • Like 1
https://www.sau.com.au/forums/topic/439497-anfanee-r32-gtr/#findComment-7207862
Thanks guys, Stuff is still in the mail. Was hoping for it to arrive on Friday but only some of it did. Trying to chase up some OEM parts that have broken. Looking for reverse lights (prefer brand new) and the rear speaker covers (Harder to track down than a clean hooker!).
https://www.sau.com.au/forums/topic/439497-anfanee-r32-gtr/#findComment-7208446
How did you manage to find speaker covers? They are definitely hard to find?
I have a set but they are dented.
Sourced directly from Nissan. Still waiting on a final price. Fingers crossed. I have been searching for like 6 months.
https://www.sau.com.au/forums/topic/439497-anfanee-r32-gtr/#findComment-7208771
Could you please post a part number, as I would like to get a pair too.
CHeers :)
2817401U11
2817501U11
^^ For both. Still waiting on a reply to confirm those are the right ones as there was 2 different types made. Will confirm in the next two days.
Comment so that I can keep track of this build. Nice work mate, keep it up
Thanks Dan, Can't wait to see a build thread for your new purchase :woot:
P.S. Nice rims.
They look very similar to the LMGT4s
Good to see that you have found a good workshop that you are happy with. Half the problem with owning a performance car is taking it to a workshop which won't take you for a ride
Good job
Yeah i was very lucky these were on the car when i got it. quite hard to track down now. They are basically the same as LMGT4's but slightly thicker and more aggressive.
  • Like 1
https://www.sau.com.au/forums/topic/439497-anfanee-r32-gtr/#findComment-7209846
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
