OK well steps are under way to organise SAU VIC Garage shirts, what we need now are sponsors, if you can give me a list of potential sponsors I will contact and negociate deals with em.
Here is the shirt that we'll be getting, possibly in a different colour scheme.
Its a hard wearing poly/cotton drill with open collar, piping, epaulettes, contrast shoulder panel, cuffs and pocket
Sizes range from Small - XXX Large
Now there's some STRICT GUIDELINES on how to respond to this post:
  1. Do not post "I want one". Simply vote for it in the poll above, so I can assess the numbers.
  2. List any potential sponsors, and any contact details you may have for them, and if possible how you are related to them.
  3. Any further ideas you may have on how to make the shirts better
Sponsors can recieve either:
An embroidered logo on the arm (or both arms)
Or an embroidered logo on the front above the pocket
Their choice will depen on how mucht hey contribute. $200 is around the minimum price I'd expect for a contribution to qualify for a sponsor logo on the shirt.
Thanks for your help and input,
Shan Moorthy,
SAU VIC.
https://www.sau.com.au/forums/topic/43951-who-wants-garage-style-shirts/
  • Replies 52
More pics... and alternate designs...
The yamaha pit crew shirt is the sort of style I like, and I've included a sizing chart for you guys to pick your sizes when the time comes.
Come on people, I need 50 solid votes to even entertain putting the order in. Does anyone need doubles?
So far it looks like we might go with white shirt with Blue Epaulette and bits with the yello piping. Since as inark suggested to me in private, the orange one is already in use by the XTC crew. The green one looks wierd (reminds me too muck of HOTSKY). And apparently the fullock garage shirts are the red ones with the black lower half. So atm its a toss up between the White shirt with blue decals or the Black shirt with the blue top half.
Also need more sponsor suggestions as the total for each shirt is around $70 (with all the embroideries and everything included). Each sponsor that donates around $300 knocks off about 5 bucks per person.
If you guys aren't that keen on this then I might just make this a national thing, but then it causes issues with sponsors etc, so I'd like to keep it local.
$70 = I won't be putting order in. We need at least 5 sponsors to get it into the $40 bracket. Seeing as the shirts themselves cost $35 and then there's embroidery, its not a cheap thing to get done.
So yeah, I need a good list of sponsors and any contacts you guys may have.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
