Hey guys, wasnt quite sure where to post this question.. also im a turbo/nissan/stagea novice. Have only had the stag (rs4s) a week and she's my first turbo.. (ive learnt a sh*t tonne of things from SAU forums btw).
Okay so i was being a little lead-footed on the way home tonight and found that if i sink my shoe through the firewall, at about 4500rpm in 1st and 2nd gear mainly, there seems to be a noticeable flat spot in throttle.. almost like the revs hit a brick wall then recover. What is happening here, is it normal and how would I overcome this annoyance?
Thanks for everyones help in advance :)
→Lorry
Ps: only mod (that im aware of), is a 3" cat back
Edited by staglover
https://www.sau.com.au/forums/topic/439602-possible-stupid-question/
Depends what you mean by a flat spot. There is a noticeable dip in power when the VCT changeover happens.
On the other hand if you lose all power momentarily that could be the ecu protecting the engine against overboosting (do you have a boost gauge? do you know if you are running standard boost?) which could happen on a cold night. That's called R(ich) and R(etard) when the ecu dumps extra fuel into the system and pulls back the timing at the same time.
what's VCT? Boost cut makes sense as it feels like a total loss of power.. I just thought it would have come on a little bit later than 4500. I have a stock boost gauge, the one in the center console. Full boost has never been more than 355mmhg (6.8psi or .47bar). Plan on getting an A/M one but I cant find a 52mm that even slightly matches (any ideas?)
I have the stock airbox with a brand spankin new k&n panel filter. I've read something about a rubber pipe on the intake somewhere that collapses under boost, would that maybe something to consider upgrading?
Edited by staglover
Mmm, I don't know if the K+N is a good idea, it could be worth cleaning the afm, just in case the oil from the filter has coated the hotwire.
Usually the intake starts sucking shut around 200kw, you can either stick a small piece of 3 inch stainless pipe inside it by cutting where the corrugations are and clamping it, which will help a little, or I can supply a nice 80mm custom alloy intake that will allow any power your setup can make, and fit up to the stock bov/breather/afm.
Don't bother with the silicone intakes on Ebay, they are worse than the rubber ones.
  • Like 1
Don't over oil them, spray some electrical contact cleaner on the AFM wire when you change oil.
There is no problem using K&N filters. There may be better options out there but if you have one then just maintain it correctly and it will be fine.
Pay Scotty for a properly designed and made intake pipe.
Hmm. I thought all filters were oiled but obviously not.. ive got a brand new stock panel, ill put that on instead and clean the AFM.
Interested in the hard intake pipe scotty. May as well fix the factory flaws. How much would one of those set me back?
PM'd. :)
Thaks man. I found some pictures around forums, looks pretty top shelf. Do you make them yourself? Im super keen for one but as I just bought the car, im a little short on funds unfortunately..Id definitely like to hit you up for one in the near future though.
Okay.. different question, But related to the OP. Since this boost cut thing happened, I have irregular boost. Seems normal (6.8psi) when ot has just warmed up. After about 20mins of driving, it only makes 3psi or less. I had a listen for boost leaks, replaced a vacuum line for boost gauge but can hear a 'pssssssst' noise when I turn the engine off. Sounds like its coming from the front right (intake side) of the engine.. anything specific i should look at? So much sh*t going in and out of it, I have no idea what many lines do.. my knowledge of working on engines stops at hemi 6's.. so I've got 30+ years of technology to catch up on :O even if someone could point me in the right direction. Thanks in advance
Edited by staglover
Make up an 80mm plug to put where the afm sits, on the corrugated rubber pipe off the airbox. Stick a compressor fitting on the plug and try to put 10-20psi into the intake. This will show up any leaks and you will find them fairly quickly.
HKS Super Hybrid panel filter is the best I've found. Three layered foam insert (course, medium & fine).
Got mine off eBay from a guy in NZ. Someone over here must sell them though.
Direct fit into standard air box.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
