Hey everyone,
I'm new to Skyline's and I own a semi-automatic R34 25GT. I've owned it for a little while now and after mucking around with the triptonic feature I am completely persuaded to look at a conversion. I was originally looking at manual but the deal with the car was solid so I settled for automatic.
I know that it's not a cheap thing but I do plan on keeping the car for years to come. (On my red P's at the moment)
Can someone please help me out with advice about doing this?
Thanks!
Edited by simonl
https://www.sau.com.au/forums/topic/439651-r34-25gt-auto-to-manual-conversion/
Search for info. There's heaps of info out there.
Be budgeting a reasonable amount if cash. Heaps mire if your not doing it yourself. Was there na manual r34s? If not you will have to spend about 1500 bucks on a manual box only and it is probably thrashed.
The reason manuals are cheaper is cos a nanual conversion costs heaps more than what people think.
Get a mv automatics shift kit and get the auto working nicley. Thats my advice.
Yes, it would be a waste of money to do it to an NA car. You can very easily drop a couple of grand into such a conversion, and more depending on how things go. And with the real value of the car being not many times more than that, it is a dubious proposition. Much better value to sell the car and obtain a good manual (turbo) when it becomes legal to do so (assuming you're a P plater which is the only reason to buy an NA Skyline).
Now, on the question of value.....if you're an old bugger with some cash lying around, value is perhaps less important than a project. In which case, go right ahead. I dropped many thousands into an engine conversion/gearbox/rear subframe upgrade birthday for my car, which was probably equal to 50% of the value of the car at the time. But it is worth it to keep a nice car going for many more years. In your case, the money will be going into an NA car that would need about twice as much spent again, if not more, to make it a turbo. That will cost you more than double the difference in price between what you have now and what you want to have if you just sold and bought something else.
In terms of what you need.....You only need the small box (RB25DE or RB20DET rather than the big RB25DET box) but you will need a suitable tailshaft that you can modify ($$) and a clutch pedal and bracket, clutch master, different flywheel, clutch, gearbox crossmember, and ideally the wiring loom from a manual car (at least the part of the loom that plugs into the gearbox on the driver's side of the engine bay).
I would caution researching what effect it might have on your ABS and TCS systems (if present) because you may be messing with the speedo sensor stuff. This probably isn't a problem, but worth looking into. I'm not sure what's mounted on the diff and what's mounted on the gearbox with these later NA cars.
Edited by GTSBoy
Yeah I'm aware the cost is going to be heeeeaps. There was a few but they were definitely thrashed and had over 150*** KM's. I picked mine up for 97***KM's. The triptonic works really well but it just makes me hungry for manual :/
Yeah I mean, I could just keep the maintenance high and try my best to keep the value of the car high and then sell it when I am on my full license. I am in Vic so that means no turbo thanks to our laws. I'm almost 20 however I am on apprenticeship wages so money is somewhat a problem. I'm still deciding if I will do it but as I said before, the triptonic just makes me so damn hungry for manual, I could just imagine the car being far more fun to drive!
I do plan on keeping my car until I a have my full license so roughly 4 years or so? If I get the conversion within the first year of owning the car, I wouldn't see it being a huge waste of time. However I am aware that the conversion would cost about 1/3 or maybe half of what I bought the car for, lol. ($9,700)
Im sure you will regret it down the track. Don't do it.
Oh, Stop using the tiptronic if thats whats making you want a manual! Problem fixed!
Yeah I might, because I'll probably want something else when I can drive turbo's, lol.
Hahaha impossible, I'm already hooked on it! :(
Better off selling an buying a manual, and while your at it a different car all together :woot:.
I owned exactly what you have now a heavy, NA, automatic R34 and yes i thought about
manual conversion a lot. Im so happy i didn't put much into the car and kept it standard
as a daily. Either keep it stock as a rock and just drive it around as is, or if you cant do
that dare i say it your better off with a Honda.
Edited by starwarz
As above, do not do this.
I originally had a N/A Auto car, and f**k me what a nightmare I have had, by holding onto the same car and upgrading it.
Be honest. 100% of the things you can do to this car you can do to a turbo manual down the track. Only do these things, and transfer them to your newer car, if you don't do the smart thing and buy a GTR at the end.
You will regret it for about a day or so till the nostalgia wears off and you will one day realise the wisdom in the words of those who have walked this path before you.
Hmm yeah, after some thought I think I'll only do minor mods and keep it pretty much stock. Haha not a huge fan of Honda, I've been thinking about silvia's though...
Yeah maybe the triptonic will have to do for now. i'll just save for a mad turbo manual when I have my full license and just do minor mods to the car and have fun.
Thanks everyone for the help.
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
    • OK, now we are ready to get started. You need to remove the air boxes on each side for clearance. The cover is straightforward, undo the clips on the top and lift the front cover out of the rest of the housing. If it is tight you can remove the air filters first. The rear section of the airbox is trickier. On each side you need to remove the Air flow meter wiring which is held to the airbox with a clip; you need to get behind the clip on 2 sides if you want to remove it without breaking it - unclip the harder side and pull on the clip with medium force, then unclip the easier side and it should pop out The airbox is held onto the intake hose with a spring clamp; you need to get a flat bladed screwdriver behind the spring on both sides and pop them outwards. When you have got them in the right unclipped place they will stay there and the airbox slips out pretty freely. Put a rag in the intake to prevent anything getting dropped in there, and also to prevent you seeing that the turbo seal is leaking oil (as they do). Then. The top of the radiator is held by a steel plate, it is secured by 2x10mm and 2x12mm headed bolts . Remove them and remove the plate Also grab the bushings that hold the radiator to the plate on each side so they are not lost!
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
