Hi Guys,
I own a R32 GTS-t and i am deciding what to do with the car. I am currently seeiming
to have a lot of trouble with it and its starting to piss me off. It seems that something just
has to happen to it. for instance;
in the last couple of months this has what has happened to it;
front wheel bearings have gone
suspenion all way round has gone including bushes need to be done
clutch has gone. (been fixed but now ***ed again)
leaking water into right tail lights
window seals
among all those things that seem to just go wrong im currently battleing a caught case
in regards to the Veilside kit that i had installed for the reason below;
was fittted with text screws in the side (front bar and side skirts)
wrong colour paint
cracked the kit in more that one spot (like every corner etc)
melted the front bar with heat lamps and the indicator.
front bar pushed on to far.
and there is more to that. It also looks like the whole front bar was heated to long and has
melted the whole thing in general as i have to big shrink marks under the lights.
among this im just getting pissed with the car in general and cant enjoy my ride anymore.
My quetion to you guys is that what do you honestly think i should do
sell the car and cut my loses maybe buy a R32 GTR or R33GTS
or maybe just get something completly different and leave the whole skyline thing.
Here are some pics of the car
http://people.ozzienet.net/~oz/Pics/1/100_0079.JPG (spray painter *** ups)
http://people.ozzienet.net/~oz/Pics/1/100_0083.JPG (spray painter *** ups)
http://people.ozzienet.net/~oz/Pics/1/100_0085.JPG (spray painter *** ups)
http://people.ozzienet.net/~oz/Pics/1/linelude.JPG
http://people.ozzienet.net/~oz/Pics/1/skyl...w%20quality.jpg
unfortanelty the pics dont do justice to as much damage that the spraypainter has really done.
anyway hope u guys can help me decide what to do with the car
sorry about the long post :D
cheers
https://www.sau.com.au/forums/topic/43978-what-should-i-do/
I guess you could have picked a better crew to fit your bodykit, however the other things are just general wear and tear, sealing rubbers and suspension bits get old and tired after 10 to 12 years. It's a fact of life when you drive a 10 + yr old car
https://www.sau.com.au/forums/topic/43978-what-should-i-do/#findComment-898700
If you have spent money on it getting it to how you want it, stick with it or at least set yourself a budget not to exceed with it.
The downside to listing all the problems above is everyone on this forum who is a potential buyer is going to either be put off or be able to knock the price down based on the above problems.
https://www.sau.com.au/forums/topic/43978-what-should-i-do/#findComment-899148
WTF?!?!
They screwed the bodykit on with screws on the outside?!?!
What complete and utter morons! I suggest you post up those photos and the name of the panel beater in the WA section so everyone knows the quality work they do!!! :uhh: :uhh: :uhh:
I'd be piiiiiiiiiiiiiissed!
https://www.sau.com.au/forums/topic/43978-what-should-i-do/#findComment-899388
the general wear and tear stuff is gonna happen to any car. but I can see how you would be annoyed. I worked hard on my GTST (white 32). the whole works, everything short of the turbo and ECU were changed. but I decided that this car wasn't for me and now I'm impatiently waiting for my GTR.
but it looks nice, maybe fix it and keep it. they are hard to sell at the moment
https://www.sau.com.au/forums/topic/43978-what-should-i-do/#findComment-901596
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
