Hi all
Recently got married and Mrs is struggling with manual so I have to sell the 86.
It is completely standard.
Had has two services from Toyota with log books.
Always garaged
Two years of warranty with Toyota
Asking for $36,000 ono
Tell your friends!
Umair
I was going to say the same thing, price is a bit high for a two year old car, but then checked carsales. Man these things hold their value something epic. Wont find many GTS models under 35k (only a small handful), some caryard is even selling a brand new one for 48k
So in this case, price is fair
yep, a clean one with low kms are holding value.
the car is not even a year and a half old.
This one is a late 2012 build and was bought in January 2013 so it still has almost 2 years of Toyota warranty.
Rego is also until January 2015 so thats another $500 - $600 worth of value there.
Negotiable on price (I kind of want a GTST again haha)
  • Like 1
The GTS is the one to get as it came with the following additional features compared to the GT:
Nicer lights with HIDs
Better brakes
Better seats with leather and heat function
Knee pads
Plastics
Touch screen head unit with sat navigation, USB, bluetooth etc
Proximity key and key less start
17" Wheels & tyres
Scuff plates
Aluminium pedals
Dual zone Climate control
Nicer guages with digital speedometer
Frameless rear vision mirror
Red stiching & alloy accents
Fog lights
Boot liner
Boot release switch Sensor door lock
Nicer key
Absolutely nothing wrong with the car.
beautiful to drive
P plater friendly
My mate ordered one of these in 2012, and was told the wait was till dec 2013, so 18 months, he still brought it, so i guess this is why they hold there value. Sorry just thought I'd add this to your post mate, free bump. Glws
  • 5 weeks later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
