Hi. Im modifying my engine atm aiming for 250rwkw. So far I have front mount. 480hp turbo ngk copper .8 gfb 2 ebc. Catch can. High flow cat to custom 3inch back. What injectors will get me to my goal. What fuel pump? Do I need a metal head gasket? What about ffp? Also the biggy the ecu. I do have a tight budget for all this. All help will b appreciated.
Also check out my bake and clutch pedal question need help there also.
https://www.sau.com.au/forums/topic/440316-help-with-r34gtt-mods/
Just realised you are the guy struggling putting a de box into your car.
You will break that box with your car stock.
Why do you want to break it sooner?
Seriously dude, spend the money on a decent box that is not glass so you can enjoy the car.
Anyway here is some advice you must not have heard before
Cheap
Fast
Reliable
You can only pick 2.
^^lol i'm from nz and use ebay haha
if you are in NZ why are you running a CAT? ditch it. you don't need to change head gasket and you do not need a Fuel pressure reg. i'd recommend deutschwerks 320lph pump and there 550cc or larger injectors with a powerfc or link.
Where do you live? If you are in Auckland there is a regular Friday night meet where you can check out what other people have done and get advice and pointed to suppliers etc.
$2500 will only pay for the supply and tuning of a Link. Cheaper is a Nistune chip. Or if you can find Andy (X-Tune) he can tune and custom make a chip for you. He supplied my injectors and can probably also supply a Deatschwerks pump.
Sadly Cats are now mandatory (for about the last year or two).
really? i didn't know that? and my car has been going through warrant testing fine? is it new vehicle compliance or a requirement on all vehicles? i'd be keen to pop along to the friday night meet when i get my P.O.S chinese intercooler sorted.
Thats the impression I was under about the cat to. Qnd yes that is the turbo im using. Im from whangarei mate. Yea link is out of my budget am keen on nistune or the likes but cannot find any1 to install and tune it in auckland.
Tony (SDU president) did a bulk buy on Nistune - don't know if he has any left. Torque Performance can install and tune Nistune possibly Glenn Suckling (Helensville) as well.
    • Ok, just the way you wrote it made it look like you had the stagger the wrong way around
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
