What? Why would someone get rid of the return line?
First time I've seen that.
Did it run good when your mate bought it? Or only recently started running shit?
Take a photo of the engine for us to see what is going on.
That shows the car has a different fpr so don't expect it to look like stock setup.
I am really amazed how many people buy other people's problems. I suppose the lure of a bargain fast car sucks you in, but the reality is there is a great chance you will be chasing your tail trying to figure out what the previous owner was thinking. Hopefully it is going to be easy to get it running nice, but I don't think you are on the right track at the moment.
^ I'm more amazed at people giving up on simple fixes. What happened to swallowing your pride and getting a mech who knows the type engine to have a look.
Where do you live mate? Someone may be able to point you in the right direction.
  • Like 1
I'm on my phone now but when I get home I will put up a diagram from Nissan Fast for you. NEO's have a fuel pressure regulator, and a fuel damper set up. My engine came with no damper which caused a bit of confusion for me at first.
But get some better pics if the engine and fuel rail and put them up.
That's assuming it is just a simple fix.
As mentioned before neo has a dampner along with the regulator.
The car wouldn't run if the fuel wasn't returning to tank. The pressure would be sky high.
Fuel needs to go into the rail then to the regulater then back to the tank, which you can't tell from the photos. The dampers aren't required.
Did this car ever run right? When did the problem start?
I'm gonna say its your idle air valve. Put your head near the brake booster on the car and look at the engine. On the back of the intake plenum there is a thing bolted to it with 3 coolant/vacuum lines running to it. You should be able to see a Phillips head screw in there. Adjust that counterclockwise (I think) and that should fix all your problems. I know I had the same symptoms and it fixed mine straight away.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
