Prior to the Cooling mod; I used to use a long tapered funnel that adapts to a PET bottle.
It's a plant watering spike that you use in the garden; bought from Bunnings for about $4.
This was narrow enough to fit in the bleed point, and gave a nice bit of extra head height to allow for coolant expansion and exhausting of air, whilst not allowing more air back into the system..
Thanks daleo did you do this when car was just idling? I'm gonna do it when I get home from work then drive for a bit see how it goes.
I'll keep use posted it must be that surely bit gasket cause shows no symptoms whatsoever I could imagine doing a gasket on the vq would be a pain.
Thanks mate.
  • Like 1
Thanks mate.
I normally hold rpm at about 2000rpm for 10 second bursts, to speed coolant flow through the system, that pushes any trapped air to the high point.
Done a couple of times and it will push most of the air out. Once cool, you can top up at the bleed point using a syringe and some plastic tube. You may need to do it a couple of times.
Scotty's coolant mod just makes flushing and bleeding the system so much easier.
Also allows the cooling system temperatures stabilise much moremore quickly, & efficiently.
Highly recommended.
  • 4 weeks later...
Highly recommended.
Can you add another to the list of cooling mods Scotty? top tank of my radiator has just cracked and squirted all of the coolant out. I've fibreglassed a a temporary patch on the crack and will order a new radiator ASAP. After patching, I haven't yet got the car running without overheating in about 2km's. After reading this thread I'll put some effort into bleeding as advised. This all makes the coolant mod sound essential (anything to make this overheating situation better). I figure I might as well take this opportunity to improve the radiator. Any recommendations for superior radiator? I live in Qld - so 38 degs is common an have some mods (hopefully few more in the future).
I just finished making one for Beau, If you want a kit, send me a pm, I can send some pictures if you like and explain it's operation Lenny.
There are a few options for radiators, plastic tank and alloy, but they are all to suit the V35 and will require a few small modifications to fit.
Please! will PM you.
As for radiators. I'm pretty keen to upgrade. Even before having the top tank crack, the cooling system just didn't seem to keep up. Every time I'd drive up the toowoomba range the temp would climb. very hot days with AC on also seemed to be a challenge. That said, if the cooling system is the limiting factor as opposed to the radiator, then maybe a standard rad will do the job with the cooling mod. thoughts please?
A few mods is fine, I've already added 600mm HKS type S intercooler (from an evo that I made to fit) so have a non standard slim AC fan, 3" suction pipe (inspired by your suction pipe mod thread, boy that was a challenge) and just finished the 3" dump and exhaust, which came out really nice and quite in the end.
The standard rad is only 15mm or so, the aftermarket plastic tank rads are 30 odd. They should be more than up to the task, as long as the engine is bled properly.
The VQ is a pain to bleed, and losing 1 cup of coolant is enough to overheat the engine. With my coolant mod it becomes much quicker to bleed, and you can still drive the car home after losing 2-3L. (as I found out after the last Sandown track day)
I've got a mishimoto rad in mine, two pass, alloy unit. It required modification to mounting points to fit, but boy I'm happy with it. When the car is moving and I've had the laptop plugged into it, even on a hot day(40 degrees) AC on, it sat at 88 degrees. Even on the track, it came in after a session without using the thermo fans (so <93 degrees).
It's a bit of a pita to fit, but worth it IMO. I also have the nismo thermostat and Scotty's coolant mod. Gearbox cooler is purely external as well.
  • Like 1
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
