Hey guys,
My sincere apologies if this has been covered but its more for personal advice anyway.
The Check Engine light on my 2001 V35 250GT came on and went to my mechanic who scanned it and came up with a problem with the Cam Sensor and apparently after looking into more he found that the Timing Chain was stretching, i haven't heard of this before to be honest and wanted to see if anyone else had. My mechanic seems to think to fix it all, would be upwards of $3000 as the whole front end would need replacing (Sensors, Belts, Chain) ETC, it still drives perfectly however, so im considering just driving it into the ground.
However in saying this I really just want to get rid of the car and thought id see what people think, am i better of selling as or trading it in and of course advising of the problem with the engine and seeing what i can get or just selling for the whole thing for parts, not sure if many people want parts for these particular cars though?
Any advise would be much appreciated.
Thanks
Jay
https://www.sau.com.au/forums/topic/440493-v35-help/
Thanks for the reply mate.
In the morning when the car is cold, its make some noise but don't know if its the engine or the car just warming up because it stops after 10 mins of driving or if its warm in the morning it wont do it at all.
Any idea on what the Cam Sensors are to replace?
https://www.sau.com.au/forums/topic/440493-v35-help/#findComment-7227724
Parallel problem with the cube engines , they had similar issues and the car would report cam sensors faults. Turns out the tensioner and everything in line needed doing. It was more prominent with high mileage vehicles. You mechanic may be right.
If the idea of getting rid of it is on the cards trade it.
https://www.sau.com.au/forums/topic/440493-v35-help/#findComment-7228026
Sounds like it has the wrong oil grade in it, I have heard it many times with thin oils the mechs try and use, as Commos use 5w30 just fine. If you drop the oil and put a decent 10w40 like it should have, the noise may just go away.
Cam sensors are around $150- $200 from Nissan. I have had to replace many of these sensors over the years, some just die, some keep throwing faults occasionally. Make sure you change the right one... Or both.
At least you can do those yourself and rule out the basics. Anything else may require you to take it to a competent mechanic.
Parallel problem with stupid people making up stupid comparisons Chris. There is either a faulty part/parts which may need replacing, or the problem is otherwise an easy fix. I have cheaply repaired many of these 'cam chain' faults when their previous mech has usually suggested the chains are stretched, and it will cost 5k plus to repair apparently.(not a bad quote considering they haven't usually looked inside the engine at all, and probably have no idea what a VQ chain assembly looks like.)
I have never seen a 'stretched' chain on any motor, not to say it can't happen with a high Km poorly serviced engine. It is more likely either a chain tensioner or guide, the EVCT actuator, a faulty cam sensor or simply the wrong grade of oil. It can be hard to repair if you can't find a decent mech with VQ experience though, as most will charge you through the nose to diagnose the fault and learn the engine.
Ditch the car? Best advice I have heard for repairs yet. Thanks for helping mate.
https://www.sau.com.au/forums/topic/440493-v35-help/#findComment-7228290
^^^^^^^ Scotty speaks the truth.
I was quoted in the region of $3,500 to fix a timing chain ticking sound in my Stagea.
The mechanic happened to have a spare engine which he wanted $2,500 for as an exchange motor + $1,000 to fit.
Scotty fixed the issue in about 2 hours and from memory it cost less than $200.
Change your oil to a high quality full synthetic 10W40 and change the sensors if needed.
https://www.sau.com.au/forums/topic/440493-v35-help/#findComment-7229238
I have always run 5W-30 as per the manufacturer spec without any issues, why is this not the correct grade of oil?
If the noise only occurs with a cold engine, wouldn't a thicker oil make the issue worse?
https://www.sau.com.au/forums/topic/440493-v35-help/#findComment-7229352
You have a different engine though, don't you. Your cams are hydraulically actuated not an electronically controlled clutch like the VQ25. Also, the VQ35 doesn't have a high pressure fuel pump hanging off the exhaust cam.
Perhaps our average temperatures are higher than Japan? I know they suggest a few grades depending on average local temps.
Or perhaps it's just from doing 100's of services on VQ25's and simply learning what feels best for them here, with the least valve train noise. Only offering my wisdom here as usual Greg, your choice if you listen or not.
https://www.sau.com.au/forums/topic/440493-v35-help/#findComment-7229627
Oh, sorry, I thought you were talking about the VQ in general. The VQ35 manual recommends 5W-30. same as it does for the VQ35 engine in the locally delivered Maxima. But our climate also fits well in the 10W-40 bracket.
https://www.sau.com.au/forums/topic/440493-v35-help/#findComment-7229911
I would never recommend any engine oil 'additive'.. the oil manufacturer generally spends a few $$ on R&D to get their oil right, you don't want to mess that up with some additional chemical that the manufacturer didn't intend.
https://www.sau.com.au/forums/topic/440493-v35-help/#findComment-7230695
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
