  • Replies 63
im with rb20lagwagon, i have just been watching in the background....
perth is the only place where wolf is used so much....and its mainly because of SST and ants power beast :D
i realise wolf is still a huge upgrade and its good for the price but is there better options? why are people all over the eastern states not heading down this track?
LagWagon, You can individually trim the injectors to run richer on 5 and 6.
Fane, You obviously don't listen very hard, Wolf was huge well before Ant. But I agree is is good that both ND4SPD and GTAAH both use wolf and make over 650rwhp each:D
IMACUL8, MOTEC is good, but $8k for a decent setup, even John Munro doesn't think it was worth it;)
I'd have to say from what i have seen. Get a R32 Rb20 and then rom the sucker !!!
Cost you about the same
Wolf installed and tuned = $2k
RB20 R32 = $2000
ROM = $500
Sell old Engine = - $1000
Install bits = $500
total = $2000
You will end up with a MUCH better motor, more power, better economy etc etc etc .......
What are you really gaining by running the wolf exactly ???
If you insist on staying with the NICS, get an AFC ... cheap and done !!
8K my ass Paul ......
Paul - I strongly disagree that Wolf was huge before recent times - hell from people I talked to the early Wolfs per a piece of shit - its only since the V4 has come out that they have gained any respectablity.
Dan
IMACUL8, Price it up:D Once you have all the options you require to run at a level that ND4SPD is, it is about $8k. Wolf V4 had been out for quite a while before Ant put on in ND4SPD, and alot of Skyline owners were already choosing to use it.
Bah to aftermarket ecu's
There are so many people around the world running fast on factory ecu's and having daily drivers its not funny.
So why then do people even consider a wolf ......
Is it because factory ecu has no hand controller ?? is it about the rice ??
Yes in this guys case rom not availbe for NICS but like i said get a r32 rb20 better all round and can rom :P.
Arguing about which Engine Management is better (Autronic *cough* :P ) is a little off topic... But results speak for themselves...
http://www.autronic.com/page_files/hall_of_fame.htm
I'm certainly impressed with the 1.8L Honda making 775HP @ flywheel...
Personally i would research what you need and what you can afford and what you want to do with your car and go from there... Personally i went with Autronic because it had all the features i wanted... And also if and when i get time i can finish developing the digial dash i started... :rolleyes:
Propoganda aside time
Back on subject
No matter how good your efi is ....... your hardware is a turd
for the same dollars get a 32 eccs rb20 then safc or rom tune it
the nics has too many draw backs and theres no point sending good money after bad
On Topic: MrMayhem:werd:
Off Topic: Paul, i listen quite fine thats why im asking questions....
The biggest promoter for anything in terms of mods whether it be a turbo, a set of injectors or an ecu is that fact that someone else has already got it setup.
With a test car like ND4SPD putting out huge ponies and times down the 1/4 always in the spotlight....its easy to promote the wolf because everyone goes well Ant runs it in his car....
"If ant can do it with a wolf why cant I?"
The question that i want answered is all the people that chose ecu's before ant and all the people that dont know of ND4SPD(eastern staters) why didnt they choose Wolf? and why do perth's other top cars not have wolf's? whether it be the speedworks gtr with an hks f-con or gt51r with the autronics...
Had autronics, now ask yourself why it doesn't and now runs a Wolf.
Some of the eastern state guys are starting to run them, but there are plenty of good ECU's about, just have to have the right tuner.
hhahah Paul - and now its got a Wolf, ask hoim why he swapped it. And i hear the new r32 will have a motec ..... hmmmm so ask yourself. ;->
Dan
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
