Sweet! I have been waiting patiently for an update.
I bet you are hanging to get it running!
Yeah i am hanging i have just been so busy and on over seas trips and also setting uo my own business so i have kinda swept it to the side for a bit its killing me looking at such a mint cond 33 gtr sitting in garage wirh no engine
I got some brand new id 2000s and a custom billet twin entry rail that came off a 1200 hp 32gtr so I think I will be flowing sweet.
Just need to wait for the engine to come back and rips fuel system bolt all the fuel system im and sort out the plumbing what do you guys do run tefl9n flewi p clamped up chasis -8 to both fuel rail and reg or -6 what would be better ?
  • Like 1
  • 2 months later...
Ok guys engine has landed in Australia now will be sitting on my engine stand very soon
Quick question i have re moved standard rb26 oil filter housing im running a greed ex oil cooler kit with remote filter is it best to wack an rb20 filter housing on the engine to screw the oil kit adapter plate on ?
Got a pick of the kit, mine have always just gone on where the filter bolts onto the factory oil/water heat transfer
Is it oil cooler only or relocator to ?
If just cooler the Z145A might not fit correctly, I use a Z131 instead ( will have to double check that to be 100%, it's been a while since I have done an oil change on that car )
  • 3 weeks later...
Rips bottem end build stock 30 with prep upgrade rips baffled sump with tomei oil pump
Kelford cams head build mild port and polish with kelford 274 cam shafts and tomei cam gears
More to list i will do it soon
  • 1 month later...
    • Just a thought, was that car and auto at any point of its life? If so, maybe whoever bridged the inhibitor switch/circuit did a not so good job.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
