Nothing went bang problems with boost crepping to a very unsafe psi due to small screamer pipe (I wont mention workshop that f@#ked it up for someone that should know wat there doing) made huge HP but to unsafe for motor so my tuner has set me a rev limit of 4000rpm so I cant ruin it haha
send us some info mate. Interested to know who. Jump shotgun with someone on cruise?
1. Sell the GTR
2. Buy 350Z
3. Be slower???
they have a nice look
Don't attract the attention of the boyz in blue
Stylish car and I like that
Goes as fast as any other car on public roads
So when does the GTR go on sale?
hey guys yeah im in for the drive on sunday any idea on numbers yet.
Looking like about 30+ people and 20 or so cars.
and do u guys know if there is a pre-meet near wynnum
Not that we've arranged, a couple of us are meeting at New Market but that's a long way out of your way.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
