I was wondering if anyone out there can solve my problem.
I have an r33 gtst, and the first issue is, when i start it or when i come to a quick stop, there is a smell of raw fuel for a few seconds. its very annoying, and i belive its also got something to do with my low km / tank... i only get 250km (and thats pushing it) out of a tank. the car is pretty much stock, except exhaust and 18's.
ive been to a few mechanics who can not figure it out!!!
also this has prob got something to do with the first issue... when i give it a hit... first gear is fine, and then in second and third and so on the car ummm this is hard to explain but it "Stutters"... like it goes through the revs and at about 3K rpm it like isnt getting enough fuel or something and stutters for a sec and then continues... there is no particular pattern, it happens through all gears, but i cannot predict when. and on the odd occasion, it doesnt happen at all!!!
and all in all im not impressed with the fuel consumption. i know its not gonna be great, but for a standard r33, its gotta be better than 250km per tank.
has anyone got any solutions or know anyone that might know. im very particular about my car, and im not gonna let any dodgy person work on it. ???
im from sydney..................
https://www.sau.com.au/forums/topic/44121-can-anyone-solve-my-fuel-problem/
I am having a similiar problem with my fuel usage. I have only had my R33 for three weeks. I will try putting injector flush in tank then see, but at the moment i am getting 75 km out off 20 lt. I spoke to a couple of people and they think it might be the coolant sensor. This will have the result of causing the motor not to know the temp of the coolant and run at what it would if the engine was cold.
I will see, I have just filled my tank up.
yeah dude... one mechanic said that... the coolant sensor... i might give it a try i think its about 100 bucks. but there was also the oxygen sensor, which is a shit load more.. or it could be the other way around! lol... either way it was a lot of money for me back then so i might go ahead and change that now....
how old are your spark plugs and has your car been tuned recently ?
my sparkies are a couple months old. put in platinum spark plugs, straight from nissan... cost me a bit too.
tuned - i havnt ahd it tuned... what exactly am i looking for when i get it tuned??
i mena its had a service and all that ... every 5000kms or so....
']doing the diagnostic mode for the ECU would be a good idea to check your sensors. from there theres just alot of things it could be unfortunately :D u cant tune a stock ecu car so if its serviced and fresh plugs thats the main thing.
do i have to go to like Nisamo (UAS) or somewhere like that to get that done? a mechanic that looks after imports... any good ones around? i hear of many butchers.
i havent had a look for that topic myself on R33 diagnostics, but its a simple process to do. If your not confident doing it yourself, id say ring a proper import type workshop and just say you want to do the diagnostic and how easy is it to do yourself or can they do it. if its easy they should let you know how to do it, or take it in and they should sort it out easily enough. its just a matter of removing the cover off the ecu and putting a meter in there somewhere and interpretting the output from the computer.
id probably prefer a proper import based workshop to test it as they most likely have more experience in these areas than any old mechanic would.
Take it down to UAS and ask John to spend an hour or 2 looking over it and see if they can find anything out of the ordinary. They work on Skylines every day of the week so their will be some quick things they can check straight up.
yes that sounds like my best option... thanks to all the others for ur help :D
could be a couple of things,
1) a leak where the new unleaded only filler cap got installed for compliance,
2) a leaking/cracked fuel hose
3) leaking fuel tank
i get a bit of fuel vapor out my filler through the breather hole, but i still get 500Km per tank so i havent worried about it!
just something you could have a look for!!
F*ck 500kms... i dream of that day. is that what everyone averages?
I average around 400km and my exhaust tip is as black as black can be. My best is ~640 on a trip to Canberra and back for the Summernats earlier this year. That involved ~400km of hwy driving @ 110km/h :D
yeah why does the tip get so black... i got that too... and not only that, sometimes i can see puffs of black smoke come out!!!
there are so many things i need to learn about my car its not funny :) it shits me that i dont know....
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
