Not entirely true, I have seen cars with the CAS out by 1 tooth or so and they still start (obviously don't run well but still idled fine)
Also I have seen (My car) range between 0 and 15 degrees timing at idle. Caused when the base idle is set way too high and the ecu pulls timing to bring it down.
The ECU would be pulling timing because of knock rather then timing. The car doesnt actually know what the timing is doing, it is outputting timing based on the CAS. The CAS can be on upside down, the car still puts in 15 degrees timing relative to the CAS.
Knock on idle? I don't think so. I'm saying if the base idle, when the AAC is unplugged and timing stable at what the ecu thinks is 15 deg, is set at let's say 1500 rpm (vacuum leak or something) and the idle screw on the ecu is set at say 900rpm, once the AAC is plugged back in the ecu will pull timing until it reaches that 900 rpm. This is what makes most cars hunt.
Yeah could be. Theres no screw on the ECU in 33s. AFAIK you have to take off one of the plugs on the aac valve and the turn the screw on the AAC valve till its right. Theres something on it in the DIY section I think
Dont worry too much about the idle at the moment
Why are you re-doing the belt? I thought you had checked it multiple times already?
Dont worry about the idle, dont worry about the plugs. Just chuck a lead between cyl #1 spark plug and coilpack #1, put the timing light on there, unplug the TPS, Start the car and see what you get
There may be no need to adjust the idle. I dont recall having to drop mine and you may find that the timing is able to be adjusted. Then you can change plugs etc afterwards.
So just check the timing first
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
