If your idle is 1000 rpm with the tps disconnected then you need to adjust the idle down to 750 before checking the timing again as it may be slightly different.
As for sounding like a wrx, generally if it sounds like that then a cylinder isn't firing, from either lack of fuel or spark. Did you disconnect anything to do with fuel or ignition when you did the timing belt?
I checked it with a timing light the usual way man
I just forgot to buy a spark plug lead when I was at sprints buying the new plugs
And yeah mad082 your right, ill have to check the fsm to find out exactly the rpm I need
Misfire ended up being coilpack wiring so it idles so nicely now
yeah just checked the fsm it says 650
but your right thats very low
so it says 650 and 15 degrees +/- 2
so ill aim for 750 and 15 ish
if i get that right does that mean its set up properly now and should be fine to drive?
thanks for your help guys especially cal, helped with heaps lately
car might make matsuri now haha
What do u mean , you just said 650 ?
Ive set it at about 750- 800 now, idle is about 18 ish degrees advanced
Ecu is still pulling the timing back when it's under load
Going to check for codes tomorrow, won't be surprised if I see knock sensor code
What do you mean "under load"? The engine isn't really "under load" at idle.
You don't get a "knock" code if you have knock, you get a "knock" code if there is a problem with the knock sensors or circuitry.
  • Like 1
so i think being an old 89 gtst my ecu only has one diagnostic mode
self diagnostics? or real time...
which is giving me the all clear, code 55,
but going up the road, its still running majorly retarded and the exhaust temp light is flashing and so is the ecu light
its just flashing randomly, not any particular code or number or sequence..
does this mean the old ecus are real time or self diagnostic?
like, do i have to drive it to pick up ecu fault codes, or does it log the last 50 starts or whatever it is and remembers if it picked up a code or not
because its giving me no codes,... but still running with no power
cant find much info on it, there is only info on how to use the diagnostics, not whether its real time or self.
or whether there is different modes or not
just read this like straight after
http://performanceforums.com/forums/archive/index.php/t-67188185.html
single led ecus record last 50 starts and will flash error codes from the last 50 starts
so ive got no ecu codes
yet my ecu is still retarding the timing,
also i forgot to mention, i relocated the fuse box and moved the battery to the boot at the same time as this work. probably important, but nothing on the fuse box was cut
i might try resetting the ecu and see what that does because the leds shouldnt be flashing as im driving.
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
