What a great day had an absolute ball
Well done to all the guys who competed unlucky with the weather, surprised myself with that time hahaha
Big thanks to the guys that made the trip up to come and show support for the club really appreciate the support
Can't wait for the next one!!!
Great vids keep them coming!!
Great day watching some pretty damn impressive machinery; had pretty much every kind of weather except snow today!
Seeing the cars belt up the hill through T2 & T3 was spectacular!
Saw a bloody epic launch from you before the rain set in Nick; great stuff. ;)
Well done to all the competitors & organisational staff; and to everyone who came out for the day.
The highlights for me had to be the Blown XY that you could hear from everywhere as it slid it's way up the hill; and the Aurion V6 powered AE86 that drifted the course quicker than some cars were driving normally.
That & the Green Clubsport with the side exit. epic boganmobile.
Took vids...
* from turn 3
* of launches from behind
* of launches from in front
Well done guys!
This old fellah has to drop off minidisk to Eric as I forgot yesterday.
Talking about old phogies I counted at least a dozen older than me yesterday. Boy did I feel good!
  • Like 1
Thanks to everyone for heading up to support the club team today.
It was a great event, shame it finished a bit early due to the big storm. Lots of quick cars although some of the fancy time attack did not end up at the pointy end of the field.
1st was heafy's evo, 2nd fernance evo, 3rd mckinnon.
Our guys came home:
Nick 8th 41.24
Brian 11th 42.32
Matt 30th 46.63
Me 32nd 46.75
Maurice 41st 51.38
Well done for everyone giving it a go in tricky conditions, and from me particular thanks to Neil for handing over Cheryl's keys when I couldn't get ready in time.
And most of all, good on Nulon for putting this event together, looking forward to the next round at wake on 4 July
Was crap conditions and a shame we only got 1 sighting lap and 2 wet runs BUT it was still great fun and great to hang out with you guys! We enjoyed it!
Where else can you rip an epic skid next to a HWP car :O lol
Yes, was a shame that too few got dry runs. The field might have changed if that had happened.
I am pretty damn sure it would have changed the day... I guess it was just pot luck! Group 1 had the better luck for the first run but Group 2 definitely had the advantage for the 3rd and final run! Luckily we had the Guru Nick running in the opposite group :yes: I would have had another crack in the wet if they had let us but they called it a day :(
Big thanks for Nulon for putting the event on, shame I never got a quick dry run, my very first run in the dry was the quickest while still finding where the road went, next two run had a wet track which was a bugger, But ready to go for next year now I know the track :)
Yep my first run was the quickest time of the day too which was a bit sad as i was cruising and lost lol
The quickest speed of the day was on the 3rd run...
I was looking forward to the 35 giving the Evos a run for their money :D Oh well i am sure you will at Wakie ;)
Nice work Ciaron! Apart from that fat basterd in the pic :P
Nicks car is looking tough!
I can't believe you'd talk about Eric like that... :whistling:
More Photos
Awesome shots Ciaron; love the attitude in this one!
  • Like 1
Hahahaha!!!
The worst part about that image is its meant to be a straight line! I cant even manage that :P
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
