  • 1 month later...
i have an r33 gtst, does anyone know if a gtr one will fit straight in. I know the stock gtst one is 80amp and a gtr one is 90amp and i know that the positive bolt post is a bit bigger, i think gtst is 6mm and a gtr one is 8mm so that wont be a problem for me but i need to know which GTR one will bolt straight in to my R33 GTST, an R32 GTR or R33 GTR or an R34 GTR one
https://www.sau.com.au/forums/topic/441473-r33-alternator/#findComment-7276089
a31/c33,32,33,c34 stagea will work, the 2 pin plug is the same, the ground hole might be a tad different nothing a drill cant fix and the positive terminal can be flipped and used the opposite way if you have tabs on each end (or just trimmed ), might also need a slight drill pending application
ebay says r31 fits r33./r32 so i'd figure so
test your alt by putting a multimeter probe on the positive terminal on the alternator and the other on the neg bat/jumper terminal to confirm its not wiring like mine was
Edited by Dan_J
https://www.sau.com.au/forums/topic/441473-r33-alternator/#findComment-7276113
Have you tried looking at higher amperage after market alternators or example as follows with current price description and where to buy;
Advance 130A for R33 to R34 / black case with red pulley $ 574.18 plus freight
or
RH9 hyper-alternator 130A for RB, SR , VG series Nissan engines / silver case with blue inserts & pulley $ 554.34 freight.
from www.rhdjapan.com
just quote for either alternator from Compatibility list the more info the better and they will match to car model & engine type eg; RB25det etc.
Just remember to run heavier battery cable or get auto electrician to check your current set up
https://www.sau.com.au/forums/topic/441473-r33-alternator/#findComment-7280371
thanks for the info, i do want to eventually get a big aftermarket one cos i do have alot of audio equipment sitting there waiting to put in and its all old school kicker stuff that requires alot of power inlike there newer class D stuff but just for the moment i want to put a gtr one in cos mine is not working properly i think. And yeah im going to run all new wiring even on this alternator so when i do get a big aftermarket one it will be ready to go straight in. I actually started a new thread about wiring upgrade, i want to just use 8 gauge for the positive and negative and use stinger terminals and not the crimp on style ones i mean the proper thick allen key type ones but im not sure how the terminals will fit cos they must sit correct cos its not like you can bend these type of terminals to fit
https://www.sau.com.au/forums/topic/441473-r33-alternator/#findComment-7280645
Yep, over the past few years, I've bought 2 S2 engines and an S1 from a crashed stock skyline that I bought for parts, and both S2's had 80amp alternators and the S1 had a 90amp.
I even did a search on this forum which told me pretty much the same.....
https://www.sau.com.au/forums/topic/441473-r33-alternator/#findComment-7284667
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
