Question:
Do you figure I could pay once, but take 2 different cars out? Assuming Boz would drive one of course.
I'm not sure what QR's rules on that would be, I believe they only allow 1 car per driver.
I thought that it was the other way around. 1 driver can have a few cars, but additional drivers need to pay. McFly had the pinny and the wedge out last time IIRC.
That was lakeside. Not sure how that worked. I drive one out and he drove the other. Time permitting I may come watch.
I'm defs in mike will get the money in no later the 1 week beforehand.
Also where are the forms that we have to fill out?
HERE Zeke, you have to create a login account and purchase a licence for this year (if you don't already have one) then select the SAU event on the 07-06-2014. They need you to give credit card details but the page says no money will be charged to you as the session has already been paid for. Could everyone who is confirmed as coming please fill this form out.
Also Carl from the Evo guys has people to fill our remaining spots so anyone who is thinking about coming make up your mind ASAP.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
