Hi Skyliners!
I just got a R32 GTR which has been dyno tuned for the r33 gtr engine replacement that has been fitted,
the results form the Emmisions test were almost triple what they should have been and the guys said it is best to get a tune which brings all the numbers down to the legal limit.
I am thinking can I just switch over the ECU to a stock one with the standard tune? (can you just plug and play or do they have to be programmed to the car?)
or is it better / cheaper to get a new dyno tune for the lower emmisions - I want to keep the tune I have on the ECU later on for nay track days as it is a power tune I believe)
Help with IM20 Emmisions test, retune or stock ecu replacement...
Thanks in advance any help will be greatly appreciated.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
