i just checked it is infact connected properly to the solenoid does it mean that the solenoid is not working then?
is there a chance that it might not be getting enough power to control the solenoid becasue i connected the power line which comes from the greddy unit to the line which came from the back of my cigerette lighter?
Edited by Deathvalley
i figured out the problem.its the valve uni harness.the white thing that connects to the greddy main unit came right off.probably thats why it wasnt controling the solenoid.
is there anyway to fix that?or should i just order a replacement?
can anyone tell me how to check the solenoid.i want to see that it is working properly before i spend any money on this thing.
Can you cable tie the plug to hold it in?
To check it is working connect a bike pump to the gauge pressure line for the controller and with ignition on pump some pressure into it .
You should hear the solenoid pulsing quickly.
Edited by superben
If it were me, I would open up the main unit, solder on a couple of wires to the pads where the external socket is, bring those outside the case to a new multi-pin connector from Jaycar or similar, cut off damaged white plug and replace with matching connector from Jaycar. Job done. 15 minutes plus trip to Jaycar.
@gts boy man great idea.
i checked in jay car
http://www.jaycar.com.au/productView.asp?ID=PP2020
the small one is the picture is the one that will connect to the greddy unit if i can get them to connect the wire to the pin then i dont need to take the main unit apart i think.
i will take that route if i m unable to find a solution.
thnxx alot mate.
SUCCESS!!!
Thanks a lot @gtsboy your advice worked.i bought the white thing from jaycars and it pluged up straight to the main unit.hit 9 psi just in one run.
now i have some questions regarding tuning.
1-since i am auto should i tune it in 2nd or 3rd?
2-lets say my start boost is 8 psi and desired boost is 11 psi.DOES THAT MEAN IN A PROPER TUNE it will boost from 80 to 110?AND THERE SHOULD BE NO FALL IN THE BOOST WHEN ITS OPEN THROTTLE?
3-I am not sure what boost spike is i did only one run until 80 not sure in what gear but i saw the boost go up to 90 around 4500rpm but then it fell.IS THAT BOOST SPIKE?
thanks a lot in advance for all your help guys!!.
:yes: :yes: :yes: :yes: :yes: :yes:
Good stuff.
Tune in 2nd to start with. 3rd will have you going very fast whilst trying to see what's going on with boost. But after you've got it set up you shoudl check what it does in 3rd also. You might want to adjust it a bit.
With ref to your point 2....yes and yes. Although boost may still drop off at the top end. And that may especially happen if you're getting into R&R territory and there is just too mush fuel and too little ignition advance to keep the fires stoked. The Profec's gain setting is what you should use to try to stop the boost falling away at the top end.
With ref to your point 3....if your start boost is 8 and you're aiming for 11, then 9 is not a spike. If your setpoint was actually 8 at the time, then yes, 9 is a spike.
ya that what i was thinking if i try to tune it in 3rd gear it already goes up to 150 kmh in 5500 rpm.my car is boost 8 psi stock so i am gona tune it for 11.tomorrow i am driving to grampians so hopefully i will get it done there.
so basically spike is if it goes above my desired boost level.for eg i want 11 psi goes up to 12 at some point thats spike.
if boost goes to 11 around 5500 rpm but falls later on that means i need to adjust gain.
all good.
lets see what happens tomorrow.
couldnt wait until grampians. so went out to tullamarine just now.
i achieved 111 with
set 33
gain 33
set gain 70
the gain is too high but i could achieve constant boost throughout the rpm.
with this setting there was a slight drop like 109,108,then it was 110 and just before shifting to 3rd 111.will try to fine tune it tomrrow but is this good enuf?
if your target boost is 11psi you can probably bring up the set gain from 70 (7psi) to 90 or 95, bit closer to your desired boost level.
Or not.
The turbosmart eboost 2 recommends the set point (same as set gain on ptofec) yo be 5 psi less than setting.
But try it and see to be sure.
He's not using the turbosmart eboost. He's using the profec.....which recommends set gain a cpl of psi below target boost. Why would he follow the instructions of a different manufacturer for a completely different boost controller rather than that of the one he is using...?
Thanks for pointing out the thread title
I am aware of what he is using. I added that info so he is aware other manufacturers don't suggest setting the set point so close to the target as it can cause spiking.
Have you ever set up a profec? I have found if the set gain is too close it will spike, using a profec.
At the end of the day I don't care what he does, using it on a stock car is a waste of money.
ya setting set gain too close to wanted max boost gives boost spike.
i have it pretty much tuner actually i think its ok.
@superben.
man i just came back from grampians the roads are really nice and without any cameras so i tested out the car several times in stock boost and high boost.
i donno why u keep sayin putin the boost controller is a waste but 100-180 in 11 psi was really a lot alot faster then the stock boost.
i was actually selecting my mod list according to the HPI R34 VIDEO on youtube.
with a full turbo back exhaust system and 10psi boost they got 33kw gain on wheels.
i know i havent dynoed my car but even if i have 20 kw gain after the boost controller i dont think thats that bad.
What I was saying (badly) is that an electronic controller is a waste in your case . A cheap bleed valve would have achieved the same result for less cash.
Never the less,I'm glad it has made a decent improvement for you.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
