and just to emphasis SKs mention of 1/4 mile times and not caring of HP, in its most highest form of drag racing, top fuellers in usa have only a rough guesstimate of the hp their engines put out. If they wer so conserned about finding out a number im sure they could, but they seem to be more interested in getting good times.
Hope that reflects some of this discussion.
  • Replies 76
So obviously a joke SK, nice one :)
take the bait WA! and keep up the good work, plenty of very nice perth cars getting around now. Must be some cash over that way...?
btw the r34 n1 turbos feature pretty high on Poenix Powers low mount turbo PS chart for obviously GTR RB26 or 2600cc or whatever class it was exactly, you know what i mean. it was in the hpi 5,6 or 7... i could check it out if anyone is really interested. they also had figures for other popular low mounts... and you could see what boost/rpm etc as well....
It might be interesting if someone knew what power the r34 n1 makes when tuned for group whatever(class) racing. i think it would be prettty certain they woundnt be allowed to change the turbos.
btw im a big fan of the 34 n1's go for it burto.
See ya's mic
I'll pipe up here and say my 32 GTR ran 11.13 @ 128mph on a 1.75 sec 60ft after registering 303 rear wheel KW's the day before on a Dyno Dynamics. Full weight car, street tyres, spare wheel, the lot. (Weigh bridge cert 1630kg)
:jk: I was only joking as well when asking if Qld KW's are bigger than Southern KW's, but I don't know of a similar car that's done that? Tell me if I'm wrong... I'm sure you will. :rofl:
thats a farkin good time and big mph. What street tyres were you using? Also do you have a 2wd switch to warm the rears?
very impressive, what tyres were you running
So 303rwkw... That would correllate quite well with jezzrrr's 285awkw... If anything, that would translate to LESS than 285awkw
Yet you run 128mph, and jezzrrr runs 118mph.
jezzrrr: Do you see now, why people think that your reading is a little optimistic? :rofl:
Couple that to the fact that peak power means nothing... I just heard about a certain race between FLYBYE (making in excess of 400awkw) and a 270awkw WRX in a 600m standing start race at Bathurst (can't remember the event, I'm sure others will), and the WRX beat FLYBYE, as well as another GTR of Domenic Russo (Autostyle) lighting up the dyno with more than 400awkw :Oops:
and that people is why dyno queens mean nothing to most of us :rofl: it aint nothing without that chunk of meat under the curve :rofl::P
is anyone here able to tell us how much traction both of these cars had??? could it be possible FLYBYE lost due to having none??
I don't want to be seen to be highjacking this thread, but here goes.
Tyres used were old Avon somethings, not a drag tyre.( I actually bought these on wheels from a friend, and they were hard as rocks) 255/40/17.
No tyre warming burnouts at all, I drove around the water. Car was pretty loose still in third - minimal grip. Camber etc all set for circuit, i.e lotsa camber etc... I don't doubt the car would have gone faster if set up for drags. This car was never tuned for outright power, just maximum "punch".
Ok, so as i thought the N1s are the weak link? I'm after good reliable power that i can use every day, this car is aimed to be street friendly and see the odd track day.
SK, i was thinking of going the high flow cat as i can get one in a deal when i get the front pipes...
How quick should this get me down the 1/4? Mid to high 11s or am i dreaming?
:werd:
Power under the curve >>>>>>>> Peak power dyno queens.
No, the reason FLYBYE lost wasn't due to no traction, it was due to a power curve that resembles* this:
* A tiny bit of artistic licence has been employed in the attached diagram :D
If you want a nice street driven GTR, I would think the R34 N1s would be awesome!
Go bigger and chase mid 11s, and you'll get more lag... Personally I think stock GTRs are too laggy as they are standard... 4000rpm is WAY too late for boost to kick in for a street driven car IMHO. So going for 2540s (bad idea) would reduce boost threshold until about 5000rpm. Is that what you want???
The problem is that everyone has different definitions on what they think a "street car" is... Personally I want torque... LOTS AND LOTS of torque, and as early as possible. To be honest I couldn't give a sh1t what my peak power figure was. For a street car you should be aiming for a fat, plump, even OBESE area under your power curve, starting from as low down in the rev range as you can get it.
ND4SPD ran 140mph but shit street tyres held it back to 10.7.     504rwkw.
Does that that mean if it had less spent on the engine and some spend on decent tyres and suspension then it would have done a 9? :confused:
I gotta agree Merli. Midrange is king! 2540 is too laggy for my tatses in a streeter, and N1's drive nice. As I mentioned before, they'll do mid 11's anyway if tuned right and driven well enough. Also compare the value of the N1's, I heard a guy in Brissy scored a near new set from the UK last week for $1200.....that's a cheap upgrade!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
