Hi fellas,
I started this topic to see what kind of results some guys are getting on an engine dyno around the 600hp+ mark. In particular, actual engine torque values and rpm it is achieved (instead of measured by rolling road dyno).
So, anyone tuning on an engine dyno and have some torque figures to share; nothing specific, RB26, RB26, RB30... sorry if this topic is conflicting with the dyno result thread but it it more specific to engine dyno.
Thanks,
Mike
https://www.sau.com.au/forums/topic/442160-rb26rb30-engine-dyno-results-600hp/
I have only ever heard of maybe two RBs being tuned on engine dynos, one RB25 making ~1400hp and one RB26 making ~1700hp - probably not too helpful for this topic, most people aiming for "only" 600ish are content with a rolling road or hub dyno :)
600hp+.... they can post it in here!
I know BoostdR had some results, I can't find it however. It was an RB30 with twin -10s that made good strong power.
I don't know of any tuners or engine builders here who have an engine dyno - the only ones I have seen are in a Polytech and one in a place doing research on fuels - which is not to say that there aren't some somewhere. I have seen a video of an Aussie speed shop somewhere that has one.
There are a few in Adelaide; most would not go to the trouble of an engine dyno but IMO it is the best way to tune and run in an engine prior to fitting it to the car. Also the only way to get a true reading of torque (and engine power).
There is one up our way, costs by the time you wire it all up etc are a bit steep, we were thinking to do the run in and basic tune on it and makes life simpler if you want to inspect the engine internally or work on it, in our case we are still unsure if its the right thing for us.
Maybe. maybe not.....
Yeah mine was done in Adelaide prior to me buying it.
2.8l with turbonetics GTK850 25psi on 98 with 10% meth-- 760hp & 780nm @ 5500rpm from memory.
Will try and find the sheet.
Thanks Richard, I will have a look for BoostdR's result somewhere on the forum today too.
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
