Guys noticed for a while now, especially after going to the drags that if I'm cruising and lightly accelerate up to speed I get a whine coming from the rear, if I pop it in neutral the sound goes away
I'm guessing my diff is on it's way?
How much does it cost at an estimate to rebuild the stocker? Or is it time for an aftermarket jobby and rip skidz
https://www.sau.com.au/forums/topic/442331-my-diff-possibly-on-its-way-out/
crown, pinion, bearing and possibly a clutch pack? get a quote from diff specialist then then think about a wreckers diff with warranty and a couple of hours under the car.
Personally I would be inclined to go with option 2
I have no experience with skyline diffs, but most lose the bearings first, then obviously if you keep driving, the crown and pinion eat themselves, and most people do keep on driving.. ffs
complete rebuild is expensive, so a nice little wreckers jobbie, can be a smart choice
It's been doing it for a while, went drags again lol seems to get worse now
On another note I have an early r32 gtr with the "fins" on the diff, and advantage of going later model without the fins ? Like from a late 93/94 model? Or are they all the same
have you ever changed the oil in your diff?
I know your 32 has plenty of ponies but if it still has the factory oil in it, then that is possibly why it failed and not the extra grunt.
.... My gtst has a finned alloy cover.
Edited by Missileman
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
