I know it's early but it will give everyone plenty of notice to finish their builds and no one will have an excuse :P
Date: 20-09-2014
Time: 2-4pm
Cost: $60 Paid SauQLD member
$70 Non Paid SauQLD member
This admits the driver and 1 spectator, additional spectators will have to pay.
Spectator Cost: $20Adults, $18 Student with ID & Kids under 13 Free.
All are welcome to stay on after the QLD Event finishes & watch evening Test'N'Tune free.
To run you will need:
Requirements for Car
Helmet to Standard
Long Sleeve Shirt
Long Pants
Covered Shoes
Requirements for MotorBike
Helmet to Standard
Leather Jacket
Long Pants
Boots & Gloves
Cars cannot run quicker than 10.00 sec
Bikes cannot run quicker than 9.50 sec
To run quicker you will need a current ANDRA Licence
All helmets need to be less than 12 years old from Date of Manufacture AND meet one of the following Standards:
SNELL SA2000
SNELL SA2005
SNELL 2000 / 2005
SNELL M2000
SNELL M2005
BS 6658-1985
SFI 41.2A
SFI 31.2A
AS/NZ 1698:2006
Also a lot of people think the helmets with "AS 1698" is the same as "AS/NZ 1698:2006" and its not, they're two different classifications.
13 January 2009 - The helmet regulations have changed, any ANDRA licenced holder is to abide by the current ANDRA rule book at any event. At Test'n'Tunes and Street Series events we will be allowing street vehicles (i.e - non ANDRA licence holders) to still use the AS1698 standard helmet.
Click this link for important new Safety Requirements to run at this event: http://www.willowban...=259&PageID=259
Passenger Rides (cars only)
  • Passenger MUST be 18 years old as a minimum - ID must be shown
  • $20 per passenger - paid at scrutineering
  • Paperwork to be completed at scrutineering
  • Only one passenger permitted in the vehicle at a time
  • Passenger must have approved helmet, long sleeves, long pants and covered shoes
  • Vehicle must have passenger seat, seat belt/harness and windows must be closed
  • The passenger is only permitted to ride in the vehicle he/she has signed the entry form for
  • Vehicles must have a known performance of no quicker than 12.00 seconds.
Payment Details:
Name: Skylines Australia Queensland Club
Bank: Westpac
BSB: 034 063
ACC: 354012
PAYMENT REFERENCE: Username&DragDay
Please do not send cash in the Mail
This year we will additionally be awarding trophies for the following categories:
1. Fastest 1/4 mile overall
2. Fastest 2wd
3. Fastest 4wd
4. Fastest 60 foot
5. Fastest reaction time
Attendees:
  1. Cadmoon PAID
  2. pretX PAID
  3. Ants PAID
  4. The filthy commo bogan
  5. Bunta
  6. Philsutty PAID
  7. Cyifly
  8. methz PAID
  9. courtoR33
  10. RusH_
  11. MagicMikeZ32 PAID
  12. Kolossus PAID
  13. B-Boi34 PAID
  14. Kiwi_Phil
  15. grae35 PAID
  16. grae35's brother PAID
  17. Noys Carbon
  18. Smity42
  19. Cowdy
  20. Chris PAID
  21. Chris' mate 1 PAID
  22. Chris' mate 2 PAID
  23. Chris' mate 3 PAID
  24. Andrew Williams
  25. Carl (Evo) PAID
  26. Aaron (Evo) PAID
  27. Tony (Evo) PAID
  28. Matthew (Evo) PAID
  29. Chris (Evo) PAID
  30. Nigel (Evo) PAID
  31. Wendy (Evo) PAID
  32. Robert (Evo)
  33. Rob (Evo) PAID
  34. Adam (Evo) PAID
  35. Snus (Evo) PAID
  36. Jap032 PAID
https://www.sau.com.au/forums/topic/442533-sau-drag-day-20-september-2014/
Nup. It's what the car has from factory unless it can be proven that a drive shaft has been removed.
Add me to this mate i wil going in full force for the 2wd class !!!
Will i finaly break something this time???lets find out lol
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
