450kw and 127mph? u sure that leak wouldnt have lost you power? i run 127mph and im only just over 500hp on 24psi, only peaked at 23 for the day though.
i don't know mate.
The only way to find out would be to run again
Awesome afternoon. The Evo guys loved it. I finally got to run my Evo for the first time & managed a 12.30 @114mph.
Does anyone know what Phil's best time was in the R35 GTR? I need to pass the info on for an internet article.
Looking back at my videos, I'm starting to wonder how I would have gone if I'd let the car get anywhere near redline...
I just have too much mechanical sympathy I think.
only be way to find out
Back to Willowbank the legume (yes, legume) goes for rev limiting thrashing
Yep, still got a free pass that expires December from a time when test and tune was rained out.
Bought an open face helmet for $40 yesterday since the full face one got too hot on Saturday.
I'll go back out as soon as Sneaky Pete decides to run his car.
well Im going back this Saturday
  • Like 1
Not I :(
I have however ordered some slimline engine mounts to fit my 2.5in intake and 2.5in incercooler piping that have been sitting in the box since xmas. Might as well turn a gearbox removal into a positive right?
Not I :(
so what happened exactly Mike and what times you run?
Not I :(
Engine out?
  • Like 1
Got to the end of the quarter, slowing down, tried to shift from 4th to 3rd and it wouldn't go. Perma stuck in 4th. Was working my way into the launches having never been on MT's before. Didn't feel like I had a single clean run unfortunately. Only made 1 trip to the timeslip booth and collected 2. 1 said 12.5 @ 123, the other said 17.5 at 77.
Wideband saved me again on that run. After burnout I noticed lean. Kept a keen eye on afr's, sure enough under boost was too lean. I had figured the boost feed for FPR had come off, and I was correct, pulled up to check and it was flapping in the breeze.
Every modified boosted car should have a wideband IMO. Cheap insurance.
Engine out?
Nope not engine out. Will sling it and slide the mounts out and install the slimlines :P
100% agree on that ^
Is on my to do list as well (EFI also recommend it too)
so many more parts, so little spare cash............quick off to the for sale of parts thread
Hey mate, where did you get your helmet from. And how did the horse run.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
