Hi
Ive recently had a starting issue. tried changing the plugs and testing for spark. Tested the CAS by spinning it. Checked for fuel after the rail. got the car started by spraying start aid to the intake. It started straight away. but when throttle is applied it seem to die or drop revs till it dies.
ive recently started using united e85 so im thinking maybe dirty injectors. But when the car started it ran for 10mins without a problem. but dies when revs applied. The first time this issue occured the car died in the middle of the road, lost all power but the revs were still present. As soon i applied more throttle it died. Thereafter never managed to start it till now.
any help is appreciated as im trying to to waste money on something that isnt broke.
R3GTT, VIPEC PLUGIN
Does the FP Speed light up green when you blip the throttle?
Can you post up the fuel and IGN tables as well?
have you done the TPS and MAP calibrations (looks like you have)
Are the injectors set right?
Is the intake air temp sensor right when it says 11 degrees? Seems awful cold for this time of the year but might just be that cold there lol
mine seems to be a lil like that at the monent, i will run a bottle of injector cleaner through mine, you should do the same cos its cheap and even if it doesnt help at least your injectors will be clean lol
Edited by Mick
Get the injectors flow tested, I have seen so many sets lately blocked with black gunk... You will be chasing your tail until you know they are all flowing fine.
Do you have a fuel pressure gauge also?
I always run a bottle of injector cleaner every month when I change oil. I probably use a bottle to half a tank which is more concentrated.
I have a fuel pressure gauge too bumped up the pressure to 50psi. Didn't really help.
I really hope it's the injectors because they take a fair bit of effort to remove.
But yes ill get them flow tested and cleaned and possibly source o new filter baskets for them. Were they ASNU1100CC by anychance?
ive attached the fuel and ignition tables
10 degrees and 4 degrees? Is it really that cold there? lol
Also, and this might just be me, but I think a bottle of injector cleaner a month is a bit excessive. I never used it with my NISMO 555's and never had any issues for 2 or 3 years
Good to hear.
I have asked my injector specialist for some heated e85 specific injectors for this very reason, should fix all our cold start issues... If they can get us some, or get them designed and built.
I can see the fuel gauge dropping on cold start as I drive up the street. If these injectors fall through I may have to swap back to pootrol this winter.
yeah i thought im going crazy but the gauge moves a lot quicker just after starting it. Not sure how other peoples setups are working on E85 but here in Canberra on the very first start you need to try atleast twice for it to start. Thereafter it starts on first go , if that makes sense. I have ASNU1100CC
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
