Hi all I'm a new member first post thanks for letting me join! I've had my skyline since 98 and don't want to sell as we love it to much, but where havin a baby so I've installed all the baby friendly parts again in it no worries now I need to swap out my 30mm lower than legal height super hard suspension with something higher and more forgiving, was looking at eBay ones but I'm not sure what the ride will be like on each particular one, if someone could point me in the right direction that would be awsome. All the forums go the other way so not much to go on
https://www.sau.com.au/forums/topic/442613-new-suspension-r33-gts-t/
Well the first question is: what do you have now?
If you are just after some softer coilovers then you need to ask/find out the spring rates for your current set and compare them to what you may be looking at.
OR
You could go the Bilstein/Whiteline (or current equivalent) route.
I haven't any idea whats in there it's black and has nothing on it I can see, some mobile mechanic put it in a 10 years back
I want the softest spring rate at std ride hight, I was just going to order what the seller recommends and blindly hope for the best.
I only want to spend $800 or so cause its coming back as soon as the baby seat comes out!
Well, the best plan would be to swap the car out for a stagea for the next 18 years :P
If you are happy to work with getting a baby into the rear of a 2 door, looks into swapping your suspension with someone with a standard setup; that will be by far the cheapest and an easy swap since someone always wants to change their standard stuff for something more hectic.
"Well, the best plan would be to swap the car out for a stagea for the next 18 years "
Nope !!! No way!! Never!!!
We will mostly be using another car this is just for once a week or other rare occasions
Most the suspenion on eBay are 10kg front 8kg rear that's seems hard as I read std is 2.4 rear and 4kg front
I found a fella selling std shocks new just need to get the right springs and I'm set now
Adding spring rate to my search has yielded lots of posts so I think I can work it from here thanks for your help
Kings Springs do heavy duty (low) and pretty much standard replacement springs.
Fit a set of standard replacement Kings onto stock dampers for the softest workable ride.
Do not fit a set of heavy (low) springs onto standard dampers as the ride will be choppy and underdamped.
Kings low will work well with off the shelf Bilstein replacement dampers.
EBay coilovers WILL NOT give you what you are after. The lightest springs you can generally get on those is 6/4 kg/mm and this is far too stiff for what you're looking for. They are also generally very low tech dampers.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
