True that
Very sexual wheels, good price I wouldn't go any lower. They may just take some time to sell in this age of cheapskates and their love of fake wheels :( tax return season is right around the corner
Glws
You can pay $1000 a set new for shite and knock-offs or $1000 a rim for cream
Suppose it depends what you do with your ride, what you can afford and what you value
At the end of the day it shows
Bought and sold a lot of top quality kit on SAU (see feedback). Every single sale has been smooth and a pleasure until this one.
Most of the guys I have traded with I still speak with semi regularly in the background.
It's about asking for and paying a fair price, selling good quality kit, being honest, packing it well, paying for it quickly and make certain buyer/seller is pleased after the deal is done.
Congrats to the new owner of these Rims. A real bargain and I'm certain he'll be extremely happy.
Thanks Paul, Patience? :P
Being stuffed around several times in the back ground with extreme low ballers & deal breakers over the week got to me late last night.
Hadn't experienced that degree of it on SAU before.
aka Grumpy32
:rant: I need a drink and chill
Seems they will be picked up tomorrow evening
True that
Never a truer word spoken, take a deposit and keep it if the rest doesn't come thru. Saves some of the heartache
Wow, lowballed even further? my eyeballs came out of my head when i saw the price on these, if i hadn't bought my RE30's and these came up, would have bought it straight away. Sorry to hear you've got time wasters =\ Didn't think it'd happen on SAU xD usually happens on Ozhonda and JDMST LOOOL.
GLWS!
...been told that 2, possibly 3 ppl on evolutionoz would love to have these, but I refuse to go on that forum.
It's so refreshing to find ppl who know how to carry out a clean business transaction these days - probably because they're interspersed with sh!t.
SOLD, paid for and picked-up.
Unfortunately an earlier buyer came through first with cash prior to Chris.
So my time came up to apologise. Appreciate your understanding mate.
:cheers:
Cheers
Richard
Tried to pm you but was unable. Can you send me some pics please
If you've missed out (and I think you have), I know where there's a set of these available - also Face 2 for GT-Rs - but gold.
PM God_speed if interested.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
