I will post up the checks this afternoon and you can decide buzz.
Its hard to beleive it's an administrative error. That's like sayin the RTA has your vin incorrect on their system.
If it's not the same car then what is it?
Mistakes do get made with rego.
My dad had a motorbike for years then realised that the number plates weren't correct to the papers, two letters were swapped.
This seems like an odd situation though.
There will probably be a simple explanation - e.g. the seller has misread one of the digits on the chassis number. Did they send you a picture of the ID plates?
It would be a very elaborate fraud over more than a decade otherwise. Sounds like hard work to maybe make $10k over a 'normal' R33 GTR - the tart up job on the engine bay alone!
You'd really want to know off the auction sheet what "R" (for repaired) really means!
Grade R or Ra:
Used to mean accident car that’s been repaired, but is now used by a lot of auction companies to grade cars they don’t want to put a grade 3 on.
Either way expect a heavily repaired vehicle or something in need of major love.
Vehicle with previous accident history, indicating the car has been in an accident in the past which has since been repaired.
Cheers guys,
Don't get me wrong the car looks great but to me there is too much variables. If I was to buy it and decide to sell the car in the next 3-4 years the next buyer (assuming they did the check) will also be questioning this.
Anyone have any idea how to put up documents?
I wouldn't even be considering this anymore, to many things you can't be sure on, if the km's aren't verified or if there no auction papers I say walk away.
For that sort of coin I'd be looking at the LM spec R33 GTR that's for sale on here, would be worth a lot more then the white one in 5-10 years.
get in contact with the buyer again. ti also seems liek he has been doing some research himself. must be hard to sell.
"UPDATE.
I have been in contact with the first Australian owner of the car, and have received important paperwork including,
*Invoice when the car was purchased in 1998.
*An Australian compliance and engineering certificate, with cars km's at 4,590.
*Vicroads road worthy certificate, dated 5-3-98 also stating cars km's at 4,590.
*First vicroads rego paper from 1998."
Since purchasing the car from the original importer back in 2011 I have driven it a mere 500kms, it was freighted to my now home in NSW with the intent of using it as a daily driver, but unfortunately that has not happened.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
