ok so i put new coils on last week and worked awesome still had some spark breaking down issues but not as bad today i put in new plugs BPR5ES gap down to 0.7 now i put it all back together and fire it up it seems to be not firing on 3cyl or 6cyl i double check loose connections now i am lost :/
And after rereading your post, you disturbed the loom and it got worse, so that seems to point to the loom.
Is 5 heat range stock? That's a pretty hot plug. I use 7 heat range, most guys say go with 6 or 7. Not 5.
how i check them was pull each connetor of one at time to here to miss
That's the smart way to do it.
You can then swap coils and see if the miss moves, letting you pinpoint coil or loom.
i got them off a member off here there is spark in cyl 3 going to test cyl6 after work i got a feeling it may be a boost leak but i think maybe the coil loom is on its way out so ill just pull it all apart again tomoz and see how i go with it all just a sill question say if i a plug the loom wrong like had one swapped around will this cause a miss?
What you might want to do is a compression test on all cylinder. After that's Ok. Take out all the coil packs and unplug them along with the injector harness. Then remove the CAS sensor and test by plugging in one coil at a time from any cylinder. Let's say number one. Turn the CAS sensor clockwise with the ignition key on holding the coil with spark plug in it . You will see the spark plug fire. That ecu channel would be good and coil and plug would be good as well if spark is present. Repeat this on all coil and ecu channels. You can use this method for injectors, but a noid light would be safer and easier. I have had this happen to me and it was the plug on the ecu.
Hope it helps mate.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 🤔
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
