Think I'll do a bit of practice later tonight if I get the chance, not sure which I'll drive yet I do like the Solstice for an easy fun drive but maybe the Spec Racer or perhaps the MX5 Cup, no not the MX5, bah!!! But maybe the MX5!!! So need to practice! :P
think ill go the Ford. MX5s visibility is terrible and I find it super temperamental too. touch the brake at higher speeds and it gets very unstable, look at the car disapprovingly and it starts to understeer (even when stationary)
Yeah I did a few laps around lime rock in the srf last night. Moved the brake bias fwd a few percent and the baseline set wasn't too bad. So I'm thinking I'll race that
Edited by dontyellpl0x
One more night till the first round is upon us! If you haven't already head over to iRacing.com and sign up to the league, just search SAU Vic iRacing Championship :) And if anyone else has a number they want in particular on their car let me know otherwise I'll just numbers the cars in the order they appear on the league page.
What a great way to start the series! Clean, safe and fun racing had by all!!!
Here are the results -
10380283_10153154506624386_4171100165638
Next month sees the series at Laguna Seca on Wednesday the 2nd of July. Plenty of time to practice! :)
  • Like 1
Didn't realise I was the only one left in the crappy car until the end
The car numbers and types seem to be mixed between Qual and Race for mine and Liam's cars
Not sure why the number mixed up, do you mean the style of the numbers? Will have a look in the replay but sounds like an iRacing bug, report it to them when you get the chance :)
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
