So I changed my timing belt, tensioners and water pump but I was apparently not paying enough attention to the instructions and now I'm worried.
Before I removed the belt, I only lined up the timing marks on the two cam pulleys up top and didn't pay attention to the mark on the crank. I was careful not to move anything, but the belt was hard to get on so now I'm worried that something might have moved.
I haven't fired the motor yet and I don't want to until I know this is right. So any advice on what I should do? Is there anyway I can safely check that it's lined up correctly?
A screwdriver down the first bore can give you close to top dead centre, then make sure the marks are correct on the cams.
Make sure you turn it over by hand first a few revolutions. That way you can be sure the valves aren't hitting the pistons.
Ok so I need to get cyl 1 to tdc on the compression stroke, and at that point the two marks on the cam pulleys should line up? What about the mark on the crank - should that line up with the notch cut out on the bottom side, or should it be at the 0deg timing mark on the belt cover?
and if it turns easilly by hand (besides the resistance of compression) then the pistons arent hitting?
Edited by mistermeena
ah yep so when cyl 1 is at tdc, the crank gear mark will be lined up with the notch on the oil pump? And if it's wrong on the cam gears I need to take the belt off and adjust them in the direction closest to making them line up?
Seriously hope it all lines up lol
Belts are a bit hard to get on, abit harder when they are new. You have to get them started on each sprocket, idler & then tensioner, then evenly push the belt on all the way around, it's the easiest way.
If you have doubts, before turning the engine over, get a mirror & visually sight that crank & cam marks are lined up. Then, slip the lower cover on & sit the balancer on the crank nose by hand & see if your marks line up. Then if all good, release your tensioner, bar the engine over 2 revolutions, re-check all 3 marks. If it's good, then hold the eccentric in that position with an allen key (please, do not add more tension, your only causing premature stretch in the belt & loading the idler & tensioner bearings unnecessarily!) & torque up the bolt.
If your in Sydney I could come & have a look.
Correct.
Not exactly. The procedure is once you get the timing belt on, you rotate the engine backwards to put tension on the belt (Think it reccomends turning it over 3 times backwards by hand) then get an allen key to fit in the tensioner just to hold it in that position while you do it up.
I think thats right anyway. something along those lines anyway
Never ever turn an engine backwards (anti - clockwise)!
When fitting the tensioner, you need to wind up the spring so that after you have fitted the belt & release the tensioner BEFORE winding the engine over (clockwise) by hand, you actually already have spring tension applying force on the belt.
The whole purpose of winding the engine over (clockwise) is remove any slack from the installation process before torquing the bolt.
It just makes it hard to align the marks, as the slack is on the wrong side. Cam timing is important to get right.
I saw an RB26 actually running backwards the other day, both cams were 90 degrees out, set up like Toyota cam wheels accidentally. Exhaust was coming out the airbox and fresh air sucking in the exhaust. Once the marks were realigned properly it ran fine, didn't even bend a valve.
  • Like 1
Not to put too fine a point on it but with No1 at TDC you can still be 180 out on the cams.
So don't panic if the cam marks don't appear with No1 at TDC.
Turn the crank another revolution and then see if the cam marks are looking better when referenced against the back cover.
Don't take any notice of markings on the belt at this stage.
Not cranking an engine backwards harks from timing chain engines with hydraulic tensioners. With the engine cranked backwards, the spring pre-tensioner may be insufficient to keep the chain on the sprockets.
Yep saw the same one as you Scotty, the issue was they were black tomie cam gears and the dot was not highlighted in white, silly bugger set them up like 2Jz gears not seeing the dot.
When i got home i looked at my gears and the dots had a dab of white paint on them, go figure, maybe not genuine tomie cam gears?
I had a backup set of valves on my bench if he needed them, didnt in the end, it surprised me.
That car ended up back on the hoist a few days later, they had setup antilag on it and a new clutch, owner spent the next day doing launches showing his mates and destroyed the clutch, never gave it a chance to bed in properly.....
Hahahahaha RB26 Honda engine!
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
