New Z32 and plug $250 posted
New Bosch 040 $150 posted
New Gates racing timing belt and NSK idler and tensioner bearings $150 posted (RB25DET)
New Nissan Rb25 Thermostat $25 posted
New Gates Racing 4PK965R, 4PK925R and 4PK835R Ancillary Belts $25 posted
New Tuneagent SS highmount turbo manifold $50 pickup
Splitfire Coilpacks SF-DIS-005 Used some were sparking although should be a few good spares $50?
SS Dump pipe 3" RB25DET Flange unsure what it was off $25 Plus postage
Alloy Airbox/Filter heatshield unsure what it fits maybe R33 GTS-T? $25 Plus postage
Stock Bits R33 GTS-T S2
Offers? or going to scrap
RB25det Stock Turbo blown seals
washer bottle
frontpipe + Gutted cat
Intake Plenum
Crossover pipe with BOV
Intake snorkel
Throttlebody
Located Canberra
PM/SMS/call Cameron O418 687 94O
https://www.sau.com.au/forums/topic/444164-new-parts-r33r32/
New Gates Racing 4PK965R, 4PK925R and 4PK835R Ancillary Belts $25 posted SOLD
Alloy Airbox/Filter heatshield unsure what it fits maybe R33 GTS-T? $25 Plus postage SOLD
washer bottle
Intake Plenum
Intake snorkel
Throttlebody
Located Canberra
Splitfire Coilpacks SF-DIS-005 Used some were sparking although should be a few good spares $50? SOLD
washer bottle
Intake Plenum
Intake snorkel
Throttlebody
Located Canberra
New Z32 and plug $250 posted $225 posted
New Bosch 040 $150 posted $125 posted
New Gates racing timing belt and NSK idler and tensioner bearings $150 posted (RB25DET) $125 posted
New Nissan Rb25 Thermostat $25 posted $15 posted
New Tuneagent SS highmount turbo manifold $50 pickup $35 plus postage
SS Dump pipe 3" RB25DET Flange unsure what it was off $25 Plus postage $20 plus postage
washer bottle
Intake Plenum
Intake snorkel
Throttlebody
Located Canberra
Prices reduced
open to resonable offers
New Z32 and plug $250 posted $225 posted SOLD
New Gates racing timing belt and NSK idler and tensioner bearings $150 posted (RB25DET) $125 posted SOLD
New Nissan Rb25 Thermostat $25 posted $15 posted SOLD
washer bottle
Intake Plenum
Intake snorkel
Throttlebody
Located Canberra
Prices reduced
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
