how much power are you making and at what boost and base fuel pressure?
i'm maxing out mine but big injectors help as fuel pressure drops in the top end.
making around 300rwkw on 20psi but I can't be sure as the car was wheelspinning like crazy on the dyno
im at about 270 at 16 psi.
Cant remember base fuel pressure, but wot it was about 60psi ( if i remember correctly)
i have 1000cc injectors atm.
It cant hurt to put another one in right?
Ill run it off another 12v line to a relay, and have a y pipe connecting to 2 intank.
base pressure sounds factory. 3Bar or 43.5psi.
well, you don't really need one, and 1000cc injectors are more than big enough to compensate if the pressure drops slightly and at 16psi it probably wont. Any tuner will be able to do this.
Personally I wouldn't install the 2nd pump but it sounds like you're going to do it anyway
keep in mind you need to supply around 16-20A of current at 60psi fuel pressure with 2 of those pumps
Edited by Blackkers
More likely your fuel filter is restricting flow, unless there is something wrong with your pump install...
Does it have full 14v and e85 compatible submersible hose in the tank? Have you checked the terminals on the pump lid are clean and corrosion free, and not melting?
Just buy a genuine 460lph walbro and be done
Thats the thing...i did..
I dont want to name who i got it from, but it was a dud.
I dont want the messing around replacing it...
And i dont want another dud lol....
But, i guess ill have to..Kudos Motorsport i guess ill get it from this time?
Edited by jay-rod
The problem is there is a restriction inside the ryco style filters, not that is was dirty. (unless you tried some kind of highflow stainless mesh filter) I have seen that exact fault many times and most suspect the pump or injectors are the problem. If you had simply bypassed the Ryco it would have proved it in 1 dyno run.
As far as I know there are no knockoff Walbro 416 pumps, but some are the original petrol variant. These are cheaper but will fail quickly on e85. If this is what you bought, and it doesn't have the sealed power connector, it could explain what happened.
he did do a run without a filter Scott ...
went through 2 filters just incase, also did a dyno run without a filter...same thing.
Direct feed from battery to a relay, stock nissan hose intank, works well with e85.
As soon as i put the 255 back in...works fine..
Also I only ever used a ryco filter, had no worries....maybe my pump was a little better, but a 255 should keep up alright if its wired up properly..You checked voltage at pump?
Oh, didn't read that. :/
These are very basic pumps, unless they have had water through them they are very robust and hard to block. Can you post a pic of it if you have one?
I just cut an e85 walbro apart today, very interesting inside due to being a turbine only pump. No wonder they are so quiet... I should post some pics in here.
reg or whats the wiring like to the pump, have you used a thicker gauge wire..?
my money is on its not getting enough power...
Lets say the 255 is getting just enough power , then the 460 would die in the ass with that same power..
would explain both your problems..
It was a couple of months ago now, so hard to recall
But im pretty sure it went like this.
Idle pressure was fine, wot it would build to ~55-60 psi then drop back down to ~45-50 at full boost /16psi around 3800 -4000 rpm
Put the 255 back in and it held a steady ~60-65 psi ( my numbers could be off, but you get the general idea )
EDIT
Could it be my wiring is the problem?
I used to have amp/subs in the back, which i no longer have, so i used the same Amp wire ( 4awg i think ) to my relay.
Do you think the large gauge wire could be to low resistance? Bare in mind its many fine strands inside the 4awg, not thick wire.
Edited by jay-rod
Bigger wiring the better, and I always solder the connectors. The main problem is the thin wires at the plug on the tank, and the undersized plug pins. They need to be clean or they can melt causing similar symptoms.
Here is the Wally, not much to see, but you can easily see the rust from excess moisture. This pump was seized, drawing 30 amps, so keep your fuse at 25A.
  • Like 1
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
