how much power are you making and at what boost and base fuel pressure?
i'm maxing out mine but big injectors help as fuel pressure drops in the top end.
making around 300rwkw on 20psi but I can't be sure as the car was wheelspinning like crazy on the dyno
im at about 270 at 16 psi.
Cant remember base fuel pressure, but wot it was about 60psi ( if i remember correctly)
i have 1000cc injectors atm.
It cant hurt to put another one in right?
Ill run it off another 12v line to a relay, and have a y pipe connecting to 2 intank.
base pressure sounds factory. 3Bar or 43.5psi.
well, you don't really need one, and 1000cc injectors are more than big enough to compensate if the pressure drops slightly and at 16psi it probably wont. Any tuner will be able to do this.
Personally I wouldn't install the 2nd pump but it sounds like you're going to do it anyway
keep in mind you need to supply around 16-20A of current at 60psi fuel pressure with 2 of those pumps
Edited by Blackkers
More likely your fuel filter is restricting flow, unless there is something wrong with your pump install...
Does it have full 14v and e85 compatible submersible hose in the tank? Have you checked the terminals on the pump lid are clean and corrosion free, and not melting?
Just buy a genuine 460lph walbro and be done
Thats the thing...i did..
I dont want to name who i got it from, but it was a dud.
I dont want the messing around replacing it...
And i dont want another dud lol....
But, i guess ill have to..Kudos Motorsport i guess ill get it from this time?
Edited by jay-rod
The problem is there is a restriction inside the ryco style filters, not that is was dirty. (unless you tried some kind of highflow stainless mesh filter) I have seen that exact fault many times and most suspect the pump or injectors are the problem. If you had simply bypassed the Ryco it would have proved it in 1 dyno run.
As far as I know there are no knockoff Walbro 416 pumps, but some are the original petrol variant. These are cheaper but will fail quickly on e85. If this is what you bought, and it doesn't have the sealed power connector, it could explain what happened.
he did do a run without a filter Scott ...
went through 2 filters just incase, also did a dyno run without a filter...same thing.
Direct feed from battery to a relay, stock nissan hose intank, works well with e85.
As soon as i put the 255 back in...works fine..
Also I only ever used a ryco filter, had no worries....maybe my pump was a little better, but a 255 should keep up alright if its wired up properly..You checked voltage at pump?
Oh, didn't read that. :/
These are very basic pumps, unless they have had water through them they are very robust and hard to block. Can you post a pic of it if you have one?
I just cut an e85 walbro apart today, very interesting inside due to being a turbine only pump. No wonder they are so quiet... I should post some pics in here.
reg or whats the wiring like to the pump, have you used a thicker gauge wire..?
my money is on its not getting enough power...
Lets say the 255 is getting just enough power , then the 460 would die in the ass with that same power..
would explain both your problems..
It was a couple of months ago now, so hard to recall
But im pretty sure it went like this.
Idle pressure was fine, wot it would build to ~55-60 psi then drop back down to ~45-50 at full boost /16psi around 3800 -4000 rpm
Put the 255 back in and it held a steady ~60-65 psi ( my numbers could be off, but you get the general idea )
EDIT
Could it be my wiring is the problem?
I used to have amp/subs in the back, which i no longer have, so i used the same Amp wire ( 4awg i think ) to my relay.
Do you think the large gauge wire could be to low resistance? Bare in mind its many fine strands inside the 4awg, not thick wire.
Edited by jay-rod
Bigger wiring the better, and I always solder the connectors. The main problem is the thin wires at the plug on the tank, and the undersized plug pins. They need to be clean or they can melt causing similar symptoms.
Here is the Wally, not much to see, but you can easily see the rust from excess moisture. This pump was seized, drawing 30 amps, so keep your fuse at 25A.
  • Like 1
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
