I know there is a sensor that controls fuel on my rb26 according to temperature, does anyone know how I can test the one I have now, and where can I buy a new one.
I have a power fc and was also wondering if I can use that to see if the sensor is good or not.
Thanks.
https://www.sau.com.au/forums/topic/444541-looking-to-find-a-new-sensor/
Coolant temperature sensor. Do some googling for the expected resistance vs temperature. Test it in hot water on the stove with a thermometer (at one cold temperature and one hot temperature) and see if it lines up with the spec.
You can buy a new one from Nissan, eBay, about 30 trillion on-line retailers, etc.
Edited by GTSBoy
Don't RB26s run an air temp sensor to measure how hot the air going into the engine is? I would put that one ahead of the coolant sensor.
Pretty sure you will find that would actually have far less of an effect on the fuel ratio.
Edit.
Actually I'm not sure the ecu even uses it.
Edited by Ben C34
I pulled my plugs and seem like its running rich. And at one point it was hard to start. Once started it runs fine. Looking at idle my afr gauge was around 12s. I would have to go into my power fc and manually pull fuel out to get it to read around 14s or less. Im still waiting on some parts to reach then ill test and tune things. I have a strong feeling that my temp sensor is acting up.
The ECU uses it, but as far as I can tell, not for anything in the day to day setting of mixtures or timing. I think it is only there to call a halt to proceedings if temperatures get way too hot.
i think it uses it to pull ign timing when inlet temps get too high....i'll double check though.
Edited by Badgaz
looks like it'll do both, however it is inj vs airT and boost. which i'm guessing might only be enabled if you have the PFC boost control kit. 50 degree airt = 0 60 degree airt = 3 degrees retard 70 degree airt = 5 degrees retard
i think i have this same problem with my wifes GTR...the temp never went over 75 on a night of logging and tuning which meant it was always getting slightly more fuel across the whole map.
Doesn't really matter what the PFC does with it....it matters what the factory ECU does with it. Which isn't much.
Face it, about the only Nissan engines that have the air temp sensor are the RB26 and the SR20. And the sensor is a big lumpy slow reacting piece of crap better suited to measuring coolant, so it's hardly going to be used for serious business. That's why we have air flow meters.
  • Like 1
its much colder here in NZ. it was about 8 degrees that night. it matters to me what the PFC does to it....and i don't care what the Factory ECU does, but i'll find out anyway...and i think the OP has a PFC. Just checked my logs and water temp was sitting 75 degrees to 77 the whole time...the IAT was showing 30 degrees....
Badgaz, GTSBoy was referring to the air temp sensor, not the coolant temp.
It sounds like your wife's car might have a low temp thermostat installed. Which sucks. Alternatively you could look online and fine the resistance at various temps for the coolant temp sensor and test it with a meter. I would do that before pulling out the thermostat.
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
