  • Replies 77
my suggestion - if you can't win, at least do something spectacular so you get your head on telly
I had my first track day ever in Feb this year. I'm not going to win it! LOL
But if nothing else my car is damn sexy (Bayside Blue R34 GTR with Bronze LMGT4's) so that should be enough to get on TV if nothing esle. But the plan for this year is to mostly have some fun and learn what its all about cause the car is still pretty stock and Im still a novice. Next year the car will (hopefully) be a beast and I'll take it a bit more seriously.
But this time around I'll definitely be having some fun so at times will try and be entertaining! haha. I have to so that I can try and increase the number of SAU Vic entries for future events.
yeah we went from 3 forum members running last year to 6 this year...they need a bit of encouragement ;)
good luck with it, its plenty of fun, and there was only a couple of tracks in nsw where the car was in any danger, not sure what its like down there....
It's Official..
DVD it is...
I managed to get a really good quote for dubbing that made it worthwhile going for the DVD over the VHS.
I dropped them off this arvo for dubbing and I should be picking up the copies at the end of this week. - I have just finished the cover for the DVD case so all going well, you should have them in the next week or so....
I can't wait until Melbourne now...
I even get my own press car to zip around in and get exposure for... :D
for those of you who subscribe to MOTOR mag, there's a dutton article in there too :rofl: I believe I see a 350Z convertible with HGE plates in there too ;) ;)
Mag should be out in newsstands shortly! ;)
god help us, Kel's offering to do an autograph session for all her fans ;)
DVD's are ready..
Where do you live Duncan ???
abbo cove in //iddleside....do you have them :wave:
Kel picked up Fast Fours and Motor today. I'm sure all the homeboyz were amazed to see a grl buying them :D
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
