hey guys i have r33 gtr the rb26 head has been serviced with
Hks cams
Hks cam gears
Valve stem seals and all replaced.
R34 gtr ball bearing turbos still ceramic housing
The car made 270kws at peak 21 but actuators brought the boost down to 16psi
Now since yesterday the motor haa been blowing alot of blue smoke under boost load and on idle if you rev the car.
The car was overfilled also bout 1.5ltrs of oil but i fixed that and now its perfect. How do i check if its my piston rings or my turbo seals blown ? Ever since it blew smoke it doesnt come on boost as hard
Don't know what to expect.
But what is important is that all cylinders are pretty much the same.
It's extremely unlikely that all pistons would die at the same time.
So the actual pressure result doesn't mean much, but the difference between cylinders is crucial.
Oil going into to the turbo inlet is from blowby.
Oil coming out of the turbo unto the intercooler pipes (with none in inlet) means it's the turbo leaking oil ;)
Edited by Ben C34
Ok so if it was turbos that means it wouldnt blow into the exhaust if it blows into the intercooler?
So most likely its motor?
If its motor and i run a catch can will it fix the issue partially?
The car doesnt go as hard now the blww smoke has come
I don't know what you mean
If oil is coming out of the turbos it will go into the intercooler pipework then into the engine and get burnt and make blue smoke.
If there's tonnes of blowby all of a sudden a catch can might do something, but doesn't fix the cause of the issue.
Get some speed up without boosting in say 3rd or 4th and then (preferably on a long down hill (if you have such a thing where you are) take your foot of the throttle and after a few seconds floor it. A big puff of smoke will suggest oil being sucked past the rings. But compression test to confirm. If you have poor compressions no catch can will restore lost power - start saving for engine out!
The engine was sitting for 4-6months without use on a crate.
The engine was never blowing smoke and all of a sudden it just started blowng smoke doesnt piston rings occur slow?
Boosting ceramic turbos to 18psi
I will check for compression if all good then would it be the turbos?
Yeh my dipstick popped out the other day while driving and im thinking because of overfilled oil and im guessing atleast 2ltrs came out and it was atill way pverfilled on the dipstick and it popped again and let oil out and still overfilled
Im going to do oil change tonight and put lucas neil additive to thicken the oil and see if it stops the blowig smoke if it does then we know its rings and if it doesnt at least minimise th smoke then turbos
Just empty it to the correct height and see what happens. That lucas stuff is as thick as gear oil, it's for extreme circumstances. Not testing.
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
