Im guessing it was overfilled by atleast 2 ltrs but it was never blowing as much snoke the. Last couple of days so doesnt make sence.
We will see soon what happens but atm still no idea
You must have some idea.
It's either due to your crazy overfill.
Or engine has busted some ring lands
Or turbo seals have gone.
As discussed in this thread.
  • Like 2
Oil dipstick being forced out also sounds like excessive crank-case pressure build up.
Could be worn rings creating excess crankcase pressure or blocked breather setup not allowing crank to breathe.
Excess crankcase pressure could also cause oil seals to leak..
Ok my comp were 160s across the board.
I changed oil put oil thickner in it and it stopped blowing blue smoke under boost only sometimes and now it just blows on idle when revving blue smoke occurs and when coming of the excellerator underload it blows blue smoke
Its now blowing alot of black smoke and big flames and all of a sudden theres no performance in second gear!
Third gear is coming on boost but not as it use to very slow and not as crazy. My dipstick is blowing anymore and i checked my pcv hoses including one to the turbo and theres only a smir of oil but theres smoke coming out of the hoses have no idea what that means but no oil at all? Im leaning towards turbos only because the performance of the car is really bad and it all of a sudden running really f*kn rich?
Any thoughts i will not purchase a catch can if theres no excessive oil coming out the breather system. Maybe valve stem seals?
Any ideas im leanig towards turbos guys but again therre was only a smir of oil in the intercooler pipe nothing crazy
Yeah maybe you should stop driving it so much while there is a definite issue with the car, you could have even destroyed the turbos running that much boost. Park the car up and remove the intercooler piping to the turbos and have a look there like the guys have said. There shouldn't be very much oil but if there is pooling there that is your issue. Pull the dumps off at the rear of the turbos and have a look in there as well, you might be missing the exhaust wheel on one turbo. If you haven't got the mech know how to get that done just tow it to your mechanic and leave it there until it is diagnosed. It's not worth destroying your engine by running it and trying to boost while you have some major oil issue.
  • Like 1
Ok i am guessing it is valve stem seals as comp test shows all same readings across the board.
Turbors are very non responsive but still making boost just not as aggressive so thats 1 problem but im saying valve stem seals purely because it now happebs in 3gear and 4 th when i give it to about 6-7000rpm abd deexcelerate and let the rpms fall smoke gushess out everywhere like a bush fire abd its blue. Its there when im boosting it but jot as much as when im deexcelerating the car so my gues is valve stem seals i put oil thickner with 10/40 and did nothing at all?
Nothing no smoke when i remove cap or dipstick! When i remov the hoses for pcv system i see smoke coming out of the hoses?
Just a bit like very little smoke.
I will rip of all the piping tonight and look closer to the intrcopler for oil because i removed the big ass intercooler pipe near the Y pipe and smir of oil pn the pipe so thats why i discard it from being turbos though ill take of the pipe to the cooler and see if its all hanging down there i want an excuse to go single loll
The fact it doesnt do it on idle when cold shows me its only on revving down from high rpm and underload on boost and on idle when revving it!
I dont think turbos it might be but i dont think so there was a smir of oil in Y pipe i think valve stem seals or maybe a piston ring landin
The pinging was only here and there maybe happened 5times worse was 109 on knock sensor but after i changed spark plugs and drove it around stopped happening doesnt happen in any gear now?
Smoke accured after laat drive on sunday
Valve stem seals tend to show when you have let the car sit for a bit then take off. Does it blow smoke on startup after leaving the car for a few hours? If not I highly doubt it's valve stem seals.
Also I wouldnt be putting oil thickiner in an engine that takes thin fully synthetic oil
Cylinder comp test on cold i just did one on warm showed those results im not to worried about 1-5. They all show same its number 6 at 70. Now the question remains why it happened and what part went wrong and do i blame my tuner it lasted 2 days of dyno
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
