Im guessing it was overfilled by atleast 2 ltrs but it was never blowing as much snoke the. Last couple of days so doesnt make sence.
We will see soon what happens but atm still no idea
You must have some idea.
It's either due to your crazy overfill.
Or engine has busted some ring lands
Or turbo seals have gone.
As discussed in this thread.
  • Like 2
Oil dipstick being forced out also sounds like excessive crank-case pressure build up.
Could be worn rings creating excess crankcase pressure or blocked breather setup not allowing crank to breathe.
Excess crankcase pressure could also cause oil seals to leak..
Ok my comp were 160s across the board.
I changed oil put oil thickner in it and it stopped blowing blue smoke under boost only sometimes and now it just blows on idle when revving blue smoke occurs and when coming of the excellerator underload it blows blue smoke
Its now blowing alot of black smoke and big flames and all of a sudden theres no performance in second gear!
Third gear is coming on boost but not as it use to very slow and not as crazy. My dipstick is blowing anymore and i checked my pcv hoses including one to the turbo and theres only a smir of oil but theres smoke coming out of the hoses have no idea what that means but no oil at all? Im leaning towards turbos only because the performance of the car is really bad and it all of a sudden running really f*kn rich?
Any thoughts i will not purchase a catch can if theres no excessive oil coming out the breather system. Maybe valve stem seals?
Any ideas im leanig towards turbos guys but again therre was only a smir of oil in the intercooler pipe nothing crazy
Yeah maybe you should stop driving it so much while there is a definite issue with the car, you could have even destroyed the turbos running that much boost. Park the car up and remove the intercooler piping to the turbos and have a look there like the guys have said. There shouldn't be very much oil but if there is pooling there that is your issue. Pull the dumps off at the rear of the turbos and have a look in there as well, you might be missing the exhaust wheel on one turbo. If you haven't got the mech know how to get that done just tow it to your mechanic and leave it there until it is diagnosed. It's not worth destroying your engine by running it and trying to boost while you have some major oil issue.
  • Like 1
Ok i am guessing it is valve stem seals as comp test shows all same readings across the board.
Turbors are very non responsive but still making boost just not as aggressive so thats 1 problem but im saying valve stem seals purely because it now happebs in 3gear and 4 th when i give it to about 6-7000rpm abd deexcelerate and let the rpms fall smoke gushess out everywhere like a bush fire abd its blue. Its there when im boosting it but jot as much as when im deexcelerating the car so my gues is valve stem seals i put oil thickner with 10/40 and did nothing at all?
Nothing no smoke when i remove cap or dipstick! When i remov the hoses for pcv system i see smoke coming out of the hoses?
Just a bit like very little smoke.
I will rip of all the piping tonight and look closer to the intrcopler for oil because i removed the big ass intercooler pipe near the Y pipe and smir of oil pn the pipe so thats why i discard it from being turbos though ill take of the pipe to the cooler and see if its all hanging down there i want an excuse to go single loll
The fact it doesnt do it on idle when cold shows me its only on revving down from high rpm and underload on boost and on idle when revving it!
I dont think turbos it might be but i dont think so there was a smir of oil in Y pipe i think valve stem seals or maybe a piston ring landin
The pinging was only here and there maybe happened 5times worse was 109 on knock sensor but after i changed spark plugs and drove it around stopped happening doesnt happen in any gear now?
Smoke accured after laat drive on sunday
Valve stem seals tend to show when you have let the car sit for a bit then take off. Does it blow smoke on startup after leaving the car for a few hours? If not I highly doubt it's valve stem seals.
Also I wouldnt be putting oil thickiner in an engine that takes thin fully synthetic oil
Cylinder comp test on cold i just did one on warm showed those results im not to worried about 1-5. They all show same its number 6 at 70. Now the question remains why it happened and what part went wrong and do i blame my tuner it lasted 2 days of dyno
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
