Theres a plug in the engine bay, just in front of the fuse/relay box. It joins the gearbox harness to the rest of the car. Mine was dirty and my reverse lights sometimes went funny then all of a sudden stopped
Simplistically, I would imagine the following:
Switch at the g/box
globe at the rear of car
fuse in the engine bay
and wiring to join it all together...
If you've multi'd the switch (when closed!), checked that the globes actually light up under a power source, then there is only the the wiring and the fuse to check.
That being said, did you check the switch for continuity? I found with my box/switch (R33 RB25), the only way I could verify that the switch was good was using a test light and a mini 12V battery.
Multimeter did not display/sound continuity unless powered!
Edited by R32Abuser
My reverse lights work for a second when I put it into reverse then go off. Not sure what it is they used to work when I pulled and held the gear leaver back but now they only work for the second when I first put it into reverse. Any one had this before? Thanks
Locate - Yes.
Troubleshoot - depends on how mechanically/electrically minded you are!
There is a plug at the reverse switch (on the gearbox) and in the engine bay where it joins back into the wiring loom.
Ground - I'd have to take a look and the wiring diagram to see exactly where the circuit is grounding. Something I neither have the time or the patience for at this time of the night.
Edited by R32Abuser
After checking everything again, still couldn't find the fault >.
What did you "check" and how?
He also checked everything and still doesn't work. ....
Something isn't being checked correctly.
Agreed.
As I said above, I had issues testing the circuit without having reverse selected and powered. Otherwise I got nothing...
Edited by R32Abuser
I've had the wiring diagram out
There is a plug at the tail-lights (obviously), a plug drivers side top front of boot (this may be out of sight inside the guard, I'm not real sure), the plug at the front which I mentioned before and then the plug at the switch on the gearbox
I cant find what fuse it is tee-ed off, but there are a fair few things powered off the same circuit like the de-fogger relay (rear window) so if thats working I dare say the power source is O.K.
Basically just need to test the switch, or bridge out the plug to eliminate the switch completely. Get the lights working without the switch and then you can see if the switch works. If you have power at the switch harness, then the earth is at the tail lights. If you have all the other lights + number plate lights then Earth is most likely not your problem, the Earth is common to all of them.
OP has already said he has tested the switch and it is O.K.
My switch could test fine to, i could also wiggle the gear stick while in reverse and get reverse lights going for a few seconds. Was very weird new switch fixed it. No idea if that's OP problem. Just a thought
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
