Never heard of them?
Pricing?
They are from GSL as well... Similar to the A1rm in price i think but 11ty times better!
I was trying to stop my full weight 34 on A1rm and had no chance, burnt 2 sets of pads in 60 laps or so... Swapped to Winmax and have now run 60+ laps without much sign of wear AND they stopped amazing, over and over without fade!
https://www.sau.com.au/forums/topic/445427-trw-vs-qfm-pads/#findComment-7334194
Cheers, good to know.
Would also like to know who's used the TRW pads, they are much cheaper.
Cheaper... Brakes... Not likely to end well :P
In saying that i am pretty sure i used the TRW fluid and it worked well lol
Call Greg @ GSL and he will give you the answers you need! Pretty easy to deal with!
https://www.sau.com.au/forums/topic/445427-trw-vs-qfm-pads/#findComment-7334200
Track only.... Winmax.... A1rm are garbage in comparison!
What are the Winmax like from cold? I run A1RM's atm as the car is used on the street occasionally but if the Winmax were better wearing for a similar price I'd switch to them.
What about rotor wear?
https://www.sau.com.au/forums/topic/445427-trw-vs-qfm-pads/#findComment-7334354
Worked from the minute i left the pits... Have not used them on the street as yet!
Rotor wear will be an issue i would imagine as would any aggressive pad... You can get varying compounds depending on your needs!
https://www.sau.com.au/forums/topic/445427-trw-vs-qfm-pads/#findComment-7334415
I noticed that you went for the 6.5 so I'm guessing the 4 or 5 would be better for a bit of street use.
What's the pricing like as I think the qfms were only around $130 or so from memory.
More if you're running bigger calipers like I am.
https://www.sau.com.au/forums/topic/445427-trw-vs-qfm-pads/#findComment-7334420
TRW Pads...
They have been around and known around Rally and track circles from the early 80's, heat cycle them 3 times and they become a serious track pad.
We know of a few rally privateers still running them today, they refuse to run anything else.
On my sons S2000, he had them and loved them, last pad change i upped him to EBC Red Stuff ceramic, many more $ extra and his says the TRW were better and he wants them back on the next pad change.
Edited by GTRPSI
  • Like 1
https://www.sau.com.au/forums/topic/445427-trw-vs-qfm-pads/#findComment-7334651
Yep, thats my advert, they are the ones.
Made in Spain by Lucas.
QFM are now made in Asia after talking to their agent a few months ago. (and for a while now but kept quite in the industry), cannot rember if he said Malaysia or Indonisia or other, but it was not china.
https://www.sau.com.au/forums/topic/445427-trw-vs-qfm-pads/#findComment-7335198
Well you're going to be biased, but what should my expectations be versus the A1RMs on my car?
S13 with S14/15 front calipers and standard rears, R33 Booster.
Slotted rotors, BM50.
Brake duct vents (home made though, piping from front air intakes to hub so who knows how well they work lol)
https://www.sau.com.au/forums/topic/445427-trw-vs-qfm-pads/#findComment-7335208
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
