RB20/25 Stainless Steel exhaust manifolds
Guest darrinspencer
If we can get minimum of 10 people together, I am able to get Rb20/25 T3 Turbo Stainless Steel exhaust manifold delivered to Brisbane from the USA including Customs and GST for $490 each.
These are sold by Stone racing in the USA and made from 2.6mm wall thickness and 42mm primaries.
Once we have 10 or more people together, I will require payment upfront. Once everyone has paided, I will order and pay for the manifolds. Delivery takes approx 14 days. Once they arrive you can pick them up from me in Brisbane or I will post to you at your cost approx $20.
List of people wanting one
Darrinspencer (confirmed)
51jay (confirmed)
tonygtst (confirmed)
Muaythailuke (confirmed)
TurboX (confirmed)
Vlv00m (confirmed)
Maybe's
Zoix
Camandcandice
Slyr33
GTT23
SQN180
Bbenny
Adzmax
Bbenny
Brod
  • Replies 49
.. i should probably pm about it .. but someone else may like to know as well
in relation to the stock turbo mounted position .. with these manifolds will the turbo remain in the same position or is there more modifications needed after fitting the manifold? ie the oil lines and pipiing etc
Matt
I wanna know if it's a 'slot in/slot out' proposition - re-use gaskets etc.
Then we will truly know if it's an economical and measureable difference.
T.
Guest darrinspencer
I sent off an email to ask
1. Does the turbo remain in the factory position.
answer- Yes
2. Are there any modifications needed to fit the manifold eg oil/water lines etc
answer- No
So what they have told me, the manifold should fit without any problems.
Please excuse my ignorance, but where exaclty does a starndard turbo sit, as I drive a VL with a custom exhuast manifold(rb25/30 combo). I would like to get one of these but it looks by the photos that the turbo sits on a weird angle. I just would hate to get it and find that I can't get the bastard to fit, thats all.
Is the price of 490 straight to my door? Or is there another cost involve?
Also what sort of increase would these give, on stock and aftermarket turbo.
I may be in but would have to wait a week or so before i can give 100% ok.
Also if u get 10 people, will u allow more? Or is it 10 max?
Guest darrinspencer
Need a minimium of 10 people, more people is fine.
Cost delivered to most capitals will be $20.
$490 is to Brisbane, as stated in the first post. Customs and duty and freight from the USA is included.
If we can get the 10 people plus, will order them once everyone has paided up front. Hopefully in about 1-2 weeks
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
