On my way to work this morning I got hit with some school traffic and decided to find an alternate route, and I found a cracker of a road (even if it is only a short one).
The road was a bit wet this morning from some light showers overnight, and with some multiple surfaces it creates some unexpected surprises.
Please note that this review is taken within legal road limits. I do not encourage 'hooning' or performing illegal acts on public roads. Please respect the road rules at all times and take note of advised speeds (marked in yellow) before making your own judgement.
Protheroe Rd - Forgan Rd, Cashmere (Speed Limit: 80kph)
When heading from Protheroe Road, the first left hander (40kph) is slightly banked and has an open rough asphalt surface. The apex of the corner doesn't have much grip when wet, so be careful not to hit it too quickly. As the road opens you get a nice high speed winding section up to the top of the hill before a set of blind esses (50kph) dropping down a 16% grade. The esses tighten and open up again, but be careful not to tackle too quickly as there is a solid concrete gutter on the outside that's going to make a mess of your rims if you come over the crest with too much speed. As you arrive at the end of the road keep to the inside line - the road narrows over a blind crest with loose gravel on the side of the road.
If you have any good cruise roads please share them. I'll endeavour to keep updating this first post with your favourite roads to make it easy for everyone to find them.
Edited by Simink
https://www.sau.com.au/forums/topic/445962-good-cruise-roads-in-se-qld/
I drive this section of road regularly, it's ok but there are much more fun roads around ;)
Haha, yeh definitely. Wouldn't go out of my way to sight this one, just an alternative to boring ol' Youngs Crossing! Thought it might be a good idea to start sharing these by starting with a nice little one to gauge interest.
Be good to eventually pull a map together of good drives that we can link up. My brothers and father are really into bikes. They have an awesome layout they go cruising on throughout the Sunshine Coast hinterland. I'll try to map it out sometime. It's at least a 90min loop.
The ultimate cruising road would have to my the Mt Lindsey highway through the bellbird ranges, between Rathdowne and the Kyogle turnoff (following road toKyogle isn't bad either). A lot of people take the Lions road instsead, but honestly i think the main road is better.
The road from Kyogle back to the coast isn't a bad drive either, but last i was there the surface was terrible.
Its a long way from anything though.
Thanks Pete, I'll add it :)
Mount Lindesay Highway, Rathdowney - Lindesay Creek
Submitted by 'sneakey pete'
The ultimate cruising road would have to be the Mt Lindesay Highway through the Bellbird Ranges, between Rathdowney and the Kyogle turnoff (following road to Kyogle isn't bad either). A lot of people take the Lions Road instead, but honestly I think the main road is better.
Thanks Cadmoon, that one looks like a cracker! I'll add it (with a finishing touch from Mount Mee into Dayboro - been on that drive before, it's pretty nice)
The Gap - Mount Nebo - Mount Glorious - Kilcoy - Woodford - Mount Mee - Dayboro
Submitted by 'Cadmoon'
Mt Nebo, Mt Glorious, out to Kilcoy then back via Woodford and Mt Mee...
Edited by Simink
This is the better version of this road, starts at the bottom of Mt Nebo
Cheers. Updated using Google Maps Engine. Anyone using Google Maps on their phone should be able to save it as a GPS route.
Here's a loop I'm going to check out this weekend up in the Sunshine Coast Hinterland. If you're ever doing a cruise up that way I highly recommend planning a stop at the Mary Cairncross Cafe, especially on early morning winter drives. They do massive awesome breakfasts, and have a big fireplace burning in the middle of the cafe. Toasty! Been up there a few times when it's been wet and the mist looks amazing. Would make for some good photo ops.
Sunshine Coast Hinterland loop
These link open up nicely in Google Maps app, but how to do save the Map.
I'll have to convert the others to a Maps Engine Map, but you should be able to download 'Maps Engine' app for your phone, log in to your Google account and load a saved map, then hit Directions to start navigation.
To create maps for the Maps Engine go to https://www.google.com/maps/myplaces, create a map, then save it.
Let me know if you can save the Mt Nebo route to your own maps, if not I'll have to set the permissions to allow everyone to edit them.
  • 3 weeks later...
Yes, many many goods roads are up out north east of Brisbane. Be careful though as motorbikes, police and trucks can appear so always keep well within the limits and on your side of the road.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drive beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
